Do I have everything covered?
Discussion in 'Suspension' started by TacoCo, Mar 5, 2009.
  1. Mar 5, 2009 at 10:29 AM
    TacoCo
    TacoCo [OP] Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I picked up some Toytec Coilovers from Dtrujillo63, and I'm supposed to be getting the TSB from the dealership tomorrow. I plan to order the following:
    Bilstein 5125's with a 1.5" stem conversion for the rear
    Fabtech AAL's
    Front Differential Drop
    Swaybar Relocates
    Rear Axle Shims
    Am I missing anything besides UCA's? I can't afford UCA's right now, so they'll have to wait.
  2. Mar 5, 2009 at 10:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Looks like you have everything. Dont install the diff drop unless vibes are evident after the install of the lift. None of the 4x4 lift installs I have done have had vibes, so you may want to hold off on installing it.
  3. Mar 5, 2009 at 10:53 AM
    TacoCo
    Colorado
    Cool. Thanks Chris. I had read some different thoughts on the vibe issue, so I'll start without the diff. drop, and see where it goes from there.
  4. Mar 5, 2009 at 10:59 AM
    ToyoComp
    ToyoComp Addicted Mod'r
    Tampa, FL
    07 4x4 TRD Off Road DC
    Sway-A-Way Race Runner 2.5 coil over (3" lift) & 2.0 rear shocks on TSB springs, Total Chaos UCA, ToyTec differential drop, 8128 Pro Comp wheels, Toyo Open Country RT 285/70/17, DT Long Tube headers, TRD CAI & exhaust, Line-X coated Famous Fabrication front bumper, Demello Sliders and rear bumper, Wet Okole covers, Rigid LED spot, driving & fog, bed mat, debadged & EBC Stage 4 rotors and pads
    Time and a buddy to help! Seriously, as Chris said it appears you have everything. Best of luck and post some pics when you're done.
  5. Mar 5, 2009 at 11:32 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Don't you mean hold off on the "rear shims" unless you get vibes? I didn't think the front diff drop would help/cause any vibes.
  6. Mar 5, 2009 at 11:48 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    What is this 1.5" stem conversion for?
  7. Mar 5, 2009 at 11:50 AM
    TacoCo
    Colorado
    Its' lengthen the shocks for the TSB I believe. It's what Sonny at DSM recommended.
  8. Mar 5, 2009 at 11:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Or for an AAL.
  9. Mar 5, 2009 at 11:52 AM
    TacoCo
    Colorado
    Oh yeah, or that :D
  10. Mar 5, 2009 at 5:09 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Whoa I need that then!!!!!
