Do I have everything for my Fuel injector replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Quackerjack, Nov 2, 2021.
  1. Nov 2, 2021 at 7:28 PM
    Quackerjack
    Quackerjack [OP] Teku
    Vincent
    Washington
    1999 Toyota Tacoma prerunner TRD SR5 extended Cab v6
    King shocks Upgraded suspension Leer shell Custom exhaust Deck Plate mod Upgraded Sound system Hella 500 lights 2 1/2 inch lift Fuel pump + injectors Pro comp series 69 wheels (nice)
  2. Nov 2, 2021 at 7:35 PM
    Bishop84
    Bishop84 Well-Known Member
    I haven't done a 3.4 for a few years, but the crush gaskets that go on the lines to the rails. I like to loosen them and pull off the rails individually.
    Kiloyard likes this.
  3. Nov 2, 2021 at 7:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How do you know they need replaced? Just curious.
  4. Nov 2, 2021 at 7:51 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Some people replace the fuel pressure regulator as a "while you're in there" preventive maintenance. I chose not to mess with it when I did my injectors. If you do it, make sure to also buy a new o-ring for it.
  5. Nov 2, 2021 at 7:53 PM
    Quackerjack
    Vincent
    Washington
    The truck was shaking badly and check engine light went on and got P0303, replaced spark plugs and wires, still misfire on 3 so going to do Fuel injectors now.
