Do I have leaf sag?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crosis, Dec 2, 2016.
  1. Dec 2, 2016 at 7:26 AM
    Crosis
    Crosis [OP] Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I was under the truck yesterday and noticed the rear leafs looked like they were in negative arch. I took a measurement with the bed unloaded except for the bed mat. The front shackle was 13.5" from the bottom of the lowest leaf. The second measurement was taken from the bottom of the lowest leaf where it sits on the rear axle and that was 16". Am I right to assume this is negative arch and me springs need replacing? The springs are the stock 2+1 with no TSB.
    EDIT: My truck is on the list for the spring recall.
    ChadsPride likes this.
  2. Dec 2, 2016 at 7:27 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Yes, mine were negatively arched before 1yr ownership even happened.
    srdoublecab2.7 likes this.
  3. Dec 2, 2016 at 8:05 AM
    Pigpen
    Dan
    Northwest Montana
    The TSB isn't worth the time. Buy a leaf pack and be a happy truck owner.
  4. Dec 2, 2016 at 8:11 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
    IronPeak and ChadsPride like this.
  5. Dec 2, 2016 at 9:11 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I had high hopes for the leaf replacement but if anything it actually made my truck droop MORE. The new leaf springs are just as bad if not worse than the old ones.
  6. Dec 2, 2016 at 9:12 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    If you have a second gen Tacoma with OEM springs, you have leaf sag.
  7. Dec 2, 2016 at 9:33 AM
    Crosis
    Dunedin Fl
    i guess its time to get Dakars. :annoyed:Thats going to be a PITA install.
  8. Dec 2, 2016 at 10:36 AM
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Leaf spring swap really isn't bad at all. I thought the brake lines were harder to do. Lol
  9. Dec 2, 2016 at 11:27 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Flat / Negative arch is normal for stock Tacoma leaf springs. Toyota designed it this way.
    Jimmyh likes this.
  10. Dec 2, 2016 at 11:29 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Took me 20 minutes. :notsure:
  11. Dec 2, 2016 at 11:53 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    I would get the recall springs installed before you buy Dakars or whatever and here's why. Toyota will get to break all the rusty fasteners loose for you and you'll have a new set of springs to sell. Not sure because I had the frame replaced at the same time but the recall may include new shackles and other hardware. I was able to get the heavy duty replacements because I had gotten the "harsh ride TSB" done years ago. The new springs are working fine for me and if they start to sag in the future I'll look into spending my money instead of Toyota's.
  12. Dec 2, 2016 at 12:01 PM
    ChadsPride
    this
  13. Dec 2, 2016 at 12:23 PM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    what years is the tsb for? I thought i remember my 2015 having negative arch from the get go, figured it was designed that way.
  14. Dec 2, 2016 at 12:24 PM
    T4RFTMFW
    They're designed to be flat.
    I think the TSB ends with 2011s.
  15. Dec 2, 2016 at 1:30 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The oem springs have a 'negative' arch. Mine were the same way. Now, if they are old and worn, obviously they will sag more.
  16. Dec 2, 2016 at 1:31 PM
    moondeath
    Pa, Gardners
    x3
  17. Dec 2, 2016 at 1:31 PM
    Crom
    Nick
    San Diego, CA
    Millions
    In the end, when I took them off my truck, mine were so bad they were circle shaped. o_O
  18. Dec 2, 2016 at 1:35 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That sucks. Mine are being done right now, hoping they work out well enough until I decide on a replacement leaf pack.
  19. Dec 2, 2016 at 1:40 PM
    moondeath
    Pa, Gardners
    If you're looking for a cheap and easy fix for the time being, the icons, or similar 3 leaf spring pack, will give you a slight lift and make it ride better. Mine rides way better now than just the factory springs.
    Crosis[OP] likes this.
  20. Dec 2, 2016 at 1:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't get why people don't understand this...
    spitdog likes this.
