Do I have Limited Slip Rear Differential?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TopShapeCabrio, Sep 15, 2014.
  1. Sep 15, 2014 at 9:27 AM
    TopShapeCabrio
    TopShapeCabrio [OP] Active Member
    Ontario
    07 4x4 TRD Yamaha Edition
    Raider Lo-Rider Elite Tonneau Cover, Weathertech Floor Mats, LED 4x4 Switch, Blu Logic Bluetooth, Toyota Roof Rack
    I have a 2007 Double Cab Long Box 4x4 TRD Yamaha Special Edition.
    I want to know if I have rear LSD. I can't see if there's a LSD sticker on the diff cover because of undercoat every year.
    How can I know if I have rear LSD other than the sticker?
  2. Sep 15, 2014 at 12:34 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    that is a Yamaha TRD where they delete the E-locker, so no e-locker but you should have mechanical locking diff
    The 2005 to 2008 model years came with a mechanical true limited slip locking differential.
  3. Sep 15, 2014 at 12:36 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Look on the diff for the "LSD Oil Only" sticker
  4. Sep 15, 2014 at 1:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do take this the wrong way.
    BUT DID YOU EVEN READ HIS POST.
    StihlToyota likes this.
  5. Sep 15, 2014 at 2:53 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Jack the rear up (both wheels off the ground) turn one wheel if the wheel on the other side turns the same direction it has limited slip if it turns the other way it does not.
  6. Sep 15, 2014 at 3:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Wtf is the Yamaha special edition?
  7. Sep 15, 2014 at 3:38 PM
    TnShooter
    Deogee
    STOCK
    I'd call your local Toyota Dealer and give them your VIN#
    They can tell what you have, There really isn't much info on the Yamaha Edition Trucks.
    What little I can find about them is here:
  8. Sep 15, 2014 at 4:36 PM
    jwiereng
    jwiereng Member
    my understanding is that the taco LSD is actually a open diff with some very clever computers selectively applying the brakes to the side that slips
    no special oil required, no plates to wear out inside the diff.
    Ginger-Vitis likes this.
  9. Sep 15, 2014 at 4:38 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    That's true after 2008
  10. Sep 15, 2014 at 4:45 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Some dealer package I think they had for the early 2nd gens.
    It's a TRD sport with bedside stickers and some other interior stuff
    With that being said yea it has a true LSD rear diff
  11. Sep 15, 2014 at 5:24 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If it has the 'fake' hood scoop, as delivered to the dealer (not added later) and it is a 2005-2008 model... then it is a SPORT TRD (vs. the Off Road TRD, with a normal hood)... then yes, it has the mechanical limited slip rear diff. Only the Sport TRD had that diff, before 2009.
    In 2009, all Tacomas went to the TRAC and AUTO LSD systems to provide limited slip traction control (which also works on the front diff in 4WD-HIGH) and the mechanical clutch pack rear diff is gone.
    shakerhood likes this.
  12. Sep 15, 2014 at 8:34 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Well not only the sports. Many upgraded level SR5s had and LSD rear end as well.
  13. Sep 16, 2014 at 5:53 AM
    TopShapeCabrio
    Ontario
    I will take your suggestion and drop by the dealer. I will post the result.
    The info in your link is good.
    Based on all the info, I don't think I have LSD. Thanks everyone for your input.
  14. Sep 16, 2014 at 8:36 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    If you're truck has all the colored match exterior (grill, bumper,door handles and mirrors) and hood scoop then technically it's a TRD sport...so you have an LSD
  15. Sep 16, 2014 at 9:27 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yamaha tuned the exhaust to sound more Canadian. :p
    ^This. More reliable method than checking any paperwork.
    Garvin74 likes this.
  16. Sep 16, 2014 at 5:14 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Be glad that yours is an '07 Sport with a mechanical LSD, I hate the electric LSD in my '13 and now my '14. I miss my locker of my '06 TRD OffRoad even though it eventually let me down with a rusted up actuator.
  17. Sep 16, 2014 at 5:44 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Install a mechanical LSD and turn off the electronic stuff.
  18. Sep 17, 2014 at 4:52 AM
    TopShapeCabrio
    Ontario
    Yup, I have all of those...
  19. Sep 17, 2014 at 4:02 PM
    David K
    The Off Road TRDs still have a locker.
    Of course A-TRAC is better since it works the front tires too, and it doesn't need to be disengaged to maneuver, as tire rotation isn't frozen to the other tire on the same axle.
  20. Sep 17, 2014 at 11:08 PM
    David K
    If he gets a Tacoma with a locker again, then it will also have A-TRAC, standard issue on Off Road 4WD Tacomas since 2009.
    TRAC actually is a big upgrade over the open differentials of before... I had both TRAC and 'Tracless' Tacomas, and the TRAC system takes the 4WD-HI to new levels.
    You see, spinning tires do nobody any good, but if that energy goes to turning tires that before would just sit there, you move! :cool:
