Do I have LSD? ('06 TRD Sport)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doughpat, Apr 28, 2017.
  1. Apr 28, 2017 at 8:40 AM
    doughpat
    doughpat [OP] Nerd With a Sweet Truck
    Bend, OR
    2006 TRD Sport, DCLB
    Ok....might be a noob-question, but...
    I've got an '06 TRD Sport (DCLB), automatic. I don't see any type of LSD switch on the dashboard to the left of the wheel. But I do see the LSD sticker on the rear differential.
    Is it just 'autolocking'.....or....am I missing something obvious here?
  2. Apr 28, 2017 at 8:45 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I believe the 05-08 sport models were the only ones with a true mechanical LSD. they switched over to Electronically (brake controlled) LSD's in the 09+ models
    Sandman614 likes this.
  3. Apr 28, 2017 at 8:51 AM
    doughpat
    Bend, OR
    Interesting...so it is 'always on'?
    Does this have any impact on the type of oil and/or additive I should use? Changing the oil this weekend. Planning on Royal Purple ($! ouch!) 75w90 with the LSD additive.
  4. Apr 28, 2017 at 8:53 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Yes, a mechanical limited slip is always in operation. The friction material in the differential doesn't typically like the extra slippery-ness of synthetic lubricants. Better off to buy regular old conventional gear oil and separately a tube of limited slip friction modifier.
  5. Apr 28, 2017 at 8:53 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Idk does your truck look like a truck or a kaleidoscope rainbow unicorn? If so please share
    TLDR; nothing useful in this post.
    Bullnettles and Maticuno like this.
  6. Apr 28, 2017 at 9:01 AM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    MarX and PzTank like this.
  7. Apr 28, 2017 at 9:03 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  8. Apr 28, 2017 at 9:07 AM
    doughpat
    Bend, OR
    That is awesome--I can take back this $20/qt. Royal Purple synthetic.....yaaaaay...cheap-o dino oil, here I come.
  9. Apr 28, 2017 at 9:53 AM
    Nate-O
    Nate-O Well-Known Member
    Nate
    PreRunner
    X2 on using regualr dino oil and seperate tube of friction modifier. My LSD differential on my 07 did not like the synthetic junk with the modifier mixed in from the dealer.
    Buy yourself some beer with the money you saved and have a good weekend!:cheers:
  10. Apr 28, 2017 at 10:08 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  11. Apr 28, 2017 at 10:19 AM
    doughpat
    Bend, OR
  12. Apr 28, 2017 at 10:33 AM
    doughpat
    Bend, OR
  13. Apr 28, 2017 at 11:22 AM
    Nate-O
    Nate
    PreRunner
  14. Apr 29, 2017 at 7:34 AM
    Maticuno
    2011 Suburban 2500
  15. Apr 29, 2017 at 11:16 AM
    doughpat
    Bend, OR
    Yep, took your advice and used store-brand conventional and lsd additive. Guys at the dealership also said they use conventional.
  16. Apr 29, 2017 at 12:22 PM
    Nate-O
    Nate
    PreRunner
    After you change the rear dif fluid be sure to go to an empty parking lot and do several tight left and right circles to get that new fluid mixed in good with the mechanical LSD friction plates. :thumbsup:
  17. Apr 29, 2017 at 4:14 PM
    doughpat
    Bend, OR
    Alright, all done (did front, rear and transfer case). The smell wasn't nearly as bad as all of you wimps were making it out to be. Smelled like MAN to me.
    Fluids were actually in really good shape. Just bought the truck so I had no idea when they were last changed, but I think I probably just wasted a Saturday morning and $50. Oil was still a nice light shade, and had a small coating of 'powdered' metal on the magnet (too small to really consider them 'shards' at all).
    Will do the tight-circle trick!
