Do I have the towing package?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GrantMrunner, Jul 6, 2016.
  1. Jul 8, 2016 at 4:52 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    You can get a 7-pin to 4 pin adapter at Napa for like 10 bucks.
    Looks like you have the tow package, bro
    GrantMrunner[OP] likes this.
  2. Jul 8, 2016 at 5:00 PM
    GrantMrunner
    GrantMrunner [OP] Member
    Rocky Mountains
    2011 TRD OR quad cab
    mostly stock
    Thanks for that info. Are the "chain hooks" on the receiver hitch safe to use for recovery tows? They appear fairly sturdy, but I have my doubts. Suggestions for a receiver slide-in or otherwise appreciated. Something that works w/D-rings and a good recovery strap, I suppose. I'll be shopping for those items soon.
  3. Jul 8, 2016 at 6:29 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Absolutely not. Get one of those slide in D-ring things. Also, and you probably already know this, don't use your tow ball either. I know in a pinch people will put the hitch pin though the empty reciever and a strap. But do yourself a favor and just get the D-ring thing.
    I carry one even though I have plate bumpers with recovery points now. Just in case I need to pull someone else out :thumbsup:
  4. Jul 8, 2016 at 6:31 PM
    Pigpen
    Dan
    Northwest Montana
    I carry an old worn out hitch with no ball in it for this. I have plenty of shackles in the recovery kit.
  5. Jul 8, 2016 at 7:38 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    That's a good idea. Shackle pin through the tow ball mounting hole?
  6. Jul 8, 2016 at 7:39 PM
    Pigpen
    Dan
    Northwest Montana
    Yup
    It works for towing draw bar style farm equipment too!
  7. Jul 8, 2016 at 8:38 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Nope buy a receiver hitch shackle assembly like this...
  8. Jul 8, 2016 at 9:56 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    My TRD Prerunner has the tow pac. So some do. :notsure:
  9. Jul 8, 2016 at 10:12 PM
    jkcashin
    jkcashin Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    In Canada they do.
  10. Jul 8, 2016 at 10:37 PM
    GrantMrunner
    Rocky Mountains
    mostly stock
