Do i have to be under warranty for TSB's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChrisGralnic, Mar 22, 2013.
  1. Mar 22, 2013 at 10:23 PM
    ChrisGralnic
    ChrisGralnic [OP] Well-Known Member
    Southern cali
    06 Prunner with AAL and Trd suspension W/lift
    Previous owner used to haul heavy loads, so he put an AAL on it and TRD front suspension with a lift and custom rear suspension for added weight capacity. I recently installed a tow package (Curt with lifetime warranty) So i will definitely see what this thing can handle as far as weight goes.
    I am hearing about new TSB's. Do i have to still be under warranty with toyota or the dealer to get them?
  2. Mar 22, 2013 at 10:26 PM
    R6Tuan
    R6Tuan New Member
    for tsb's usually u have to be under warranty to get them done without paying. if its a recall then it doesnt matter.
  3. Mar 22, 2013 at 10:29 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    If your close, they might do it out of good faith...but don't hold your breath
  4. Mar 22, 2013 at 10:32 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    A TSB is not a recall. TSBs were never intended to be released to the public, and not intended for us to look for problems.
    A TSB is simply a formal communication from engineering to the dealerships indicating "If a customer complains about 'x', then here is the most likely solution"
    So if the vehicle is under warranty, the TSB is covered under the normal warranty.
  5. Mar 22, 2013 at 10:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    True true... or if it's an issue that you've been complaining about for a while.
    A good reason to document any and all issues while still under warranty.
  6. Mar 22, 2013 at 10:38 PM
    ChrisGralnic
    Southern cali
    Thanks guys. My dealers pretty nice, Ive had the truck for almost a year now and have only put 7,000 on it. I had a clutch T.S.B fixed about a week after buying the truck. There was an abnormal ticking noise that they agreed was not normal. They took it as a no brainer and replaced the whole clutch for me. That was then though... Reason i ask is i have the windshield noise going on but it doesn't bug me enough to pay to have it fixed.
  7. Mar 22, 2013 at 10:43 PM
    ChrisGralnic
    Southern cali
    I bought the truck used and the warranty they had was 30,000 mile limited for like 2500 extra.. I figured i'd be fine. Luckily i brought it back within the standard dealership 1000 mile warranty for my clutch and had it replaced on the spot. I guess i won't be bugging them about the new t.s.b's i see. Lol!
    My moms corolla has a recall atm for the power windows.. Apparently they have caused fires and can overheat and melt door panels.. I really need to schedule a day to take it in and get that taken care of for her lol!
