Do I have to change my brake pads?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cajunboi, Jul 24, 2009.
  1. Jul 24, 2009 at 5:37 AM
    cajunboi
    cajunboi [OP] Member
    I changed them about 6 months ago and turned my rotors due to lack of availability of new rotors. Well of course they are warped now and I now have some new rotors to put on.
    Do I need to change the pads if they still have life on them?
    Thanks
  2. Jul 24, 2009 at 5:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You should be fine with the pads you have now.
  3. Jul 24, 2009 at 6:01 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I concur.
  4. Jul 24, 2009 at 9:41 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the pads should still be good to go............just make sure to do the break in procedure after you get new rotors and you should be fine.
  5. Jul 24, 2009 at 9:53 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    Take the pads and rub them on the concrete. This will give you a new surface for the new rotors.
  6. Jul 24, 2009 at 10:40 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    What is a break in procedure for pads and rotors? Just sand them down and make sure there clean? Or is it something different?
  7. Jul 24, 2009 at 11:15 AM
    cajunboi
    Im curious about this too.
  8. Jul 24, 2009 at 11:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You really should change them.
    New Rotors need to be 'bed in' (broke in). The old pads will have 'wear patterns' in them from the old & warped rotors. You don't want to break-in the new rotors with pads that are worn from warped/old rotors.
    I personally would never put old pads on new rotors.
    Here's a rotor break-in process.
    http://www.tirerack.com/brakes/tech/techpage.jsp?techid=85
    I'm not sure how critical this is for most everyday cars. When we changed rotors/pads on our corvette, we did the bed-in procedure.
  9. Jul 24, 2009 at 11:35 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    I would put new brake pads on so it would brake in the rotors evenly.
    Also out of curiosity, are you heavy on your brakes when you brake to slow down? Or do you just put a lot of miles on your truck?
  10. Jul 24, 2009 at 11:37 AM
    cajunboi
    Neither really. I wanted to change my rotors when I did the pads 6 months ago but no one in town had the smaller rotors for w/o VSC trucks. I eventually had to get Pep Boys to turn them and I think the guy said he made 4 passes on them. I knew they would warp but didnt have a choice at the time.
  11. Jul 24, 2009 at 11:39 AM
    4cyltacoma
    4cyltacoma Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
    i would change the pads to. better that way. and the stock rotors i think gets warpped alot i heard. going with aftermarket
  12. Jul 24, 2009 at 12:04 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    I got my Rotors from WheelersOffroad.com not a bad price.
