Do I have to change wheels when upgrading to King 2.5 Coilovers?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Guitarrocks, Jul 29, 2022.
  1. Jul 29, 2022 at 7:48 PM
    Guitarrocks
    Guitarrocks [OP] Active Member
    2020 Sr5 Tacoma
    None
    My Kings are finally here and it just occurred to me that there might be a clearance issue with +24 offset rims. Would it be fine to install them or should I wait till I get some 0 offset rims. Also anyone tried out those method bead grip wheels the 701s wondering if I get those or a full bead lock?
  2. Jul 29, 2022 at 8:13 PM
    NACAircrew
    NACAircrew Well-Known Member
    My pronoun is Chaz
    TRD OR/4R Trail
    Raptor lights/Meso everything/Predator steps
    Backspacing? What UCAs you running? I know JBAs have some tight tolerances.
  3. Jul 29, 2022 at 8:17 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Full bead lock is for when you know without a doubt you need bead lock.
    AmateurTaco1313 likes this.
  4. Jul 29, 2022 at 8:43 PM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    Probably not gonna have clearance issues with the coil over but possibly the UCA an tire size will contribute to that, the wheel offset/backspacing you select will play the biggest role.
    For rim type depends on your use but since you got kings and are asking about it I’m going to assume you have intentions of wheeling your truck. I run true beadlocks an wouldn’t have it any other way, they’re not as big of a pain that everyone points them out to be but they certainly have their cons.
  5. Jul 29, 2022 at 8:50 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
  6. Jul 30, 2022 at 10:25 AM
    Guitarrocks
    2020 Sr5 Tacoma
    None
    4.5” backspace and I haven’t changed them yet but going to be running accutune off roads new control arms atm I have a Spc arm on it
  7. Jul 30, 2022 at 10:26 AM
    Guitarrocks
    2020 Sr5 Tacoma
    None
    Yes I understand all the problems with bead lock I have them on my overland build but it’s a 96 dodge so I don’t know if it’s worse in tacomas
  8. Jul 30, 2022 at 10:47 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    If you are asking if you will have clearance issues with a coilovers then you shouldn’t even consider beadlocks
    whatstcp and NACAircrew like this.
  9. Jul 30, 2022 at 11:15 AM
    adhumston
    adhumston Well-Known Member
    A beadlock wheel is a beadlock wheel, regardless of what it goes on.
    Do you plan on airing down under 13psi or so? If not, no need for beadlocks IMO. I've aired down to 10psi in sand and didn't have issues, however I have burped a bead at 12psi in rocks
    NACAircrew likes this.
  10. Jul 30, 2022 at 1:23 PM
    NACAircrew
    My pronoun is Chaz
    TRD OR/4R Trail
    JoeCOVA[QUOTED] likes this.
  11. Jul 30, 2022 at 1:26 PM
    Guitarrocks
    2020 Sr5 Tacoma
    None
    New to tacomas so just doing my research
  12. Jul 30, 2022 at 2:30 PM
    JoeCOVA
    Joe
    Colorado Springs
    Maybe but your questions aren’t Tacoma specific.
    Lots of info here to help you along your away.
