do i have to cut
Discussion in 'Suspension' started by taco_man, Oct 4, 2009.
  1. Oct 4, 2009 at 10:09 AM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    do i have to cut into my crossmember if i have a prerunner and want to do the procomp stage i 6 inch?
  2. Oct 4, 2009 at 10:31 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Yes.
    If you did the Total Chaos or Camburg lift spindles though, you would have a straight bolt on lift.
  3. Oct 4, 2009 at 10:35 AM
    taco_man
    Austin
    Houston
    09 texas edition
    but doesnt that only give me 4 inches of lift??? and what other components would i need to get the truck level? just blocks in the rear?
  4. Oct 4, 2009 at 10:39 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    $950 - Camburg Spindles
    $300 - Bilsteins all around
    $375 - All Pro 3" Leaf pack
    $170 - OME Springs
    $60 - Extended brake lines
    Under 2K for approximately a 6 inch kit?
    Maybe after market UCA's?
    Just a thought.
    I was thinking about doing this but then I found out spindles can't be put on a 4x4.
  5. Oct 4, 2009 at 10:40 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    you can get the spindles and get 4", then get up to another 3 inches of lift from your coilovers. very easy.
    do prerunners even have a crossmember? i thought that was only 4x4s
  6. Oct 4, 2009 at 11:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Why would the cross member need to be cut, if there is no diff in the front?
  7. Oct 4, 2009 at 12:33 PM
    taco_man
    Austin
    Houston
    09 texas edition
    okay so now im confused... do i need to cut or no?
  8. Oct 4, 2009 at 1:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No.
  9. Oct 4, 2009 at 1:47 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Nope...4x4's only :)
  10. Oct 4, 2009 at 1:48 PM
    johnecon2001
    Phoenix, AZ
  11. Oct 4, 2009 at 1:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The only reason the cross member needs to be cut, is to lower the front diff, and give it clearance. No front diff = not nessesary to cut the crossmember. The added crossmember simply bolts under the existing one.
  12. Oct 4, 2009 at 1:56 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  13. Oct 4, 2009 at 1:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    John...Scrol down the instructions:
    http://www.explorerprocomp.com/PDFs/is/57096.pdf
    You will see in large Type:
    [FONT=TimesNewRoman,BoldItalic][FONT=TimesNewRoman,BoldItalic]
    IMPORTANT: IT IS
    NOT NECESSARY TO
    CUT FRAME FOR
    2WD KIT​
    INSTALLATION
    [/FONT][/FONT]
  14. Oct 4, 2009 at 2:04 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    well i guess that solves it
  15. Oct 4, 2009 at 2:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :thumbsup::cheers:
  16. Oct 4, 2009 at 2:17 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  17. Oct 4, 2009 at 4:26 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    fist bump for chris. haha
  18. Oct 4, 2009 at 4:35 PM
    98tacoma27
    Ben
    Not Beech Creek
  19. Oct 4, 2009 at 5:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    pr3runn3rz r s3riuz bizn3z!!!!
  20. Oct 4, 2009 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats Right! 4WD or GTFO!
    :p
