Do i have to regear?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma mud, Jan 12, 2012.
  1. Jan 12, 2012 at 2:02 PM
    Tacoma mud
    Tacoma mud [OP] Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    I was planning on getting a 3" susp lift and a 2" body lift, with 35 x12.5 tires. Would i have to regear?
    I know bl are bad but 2" isnt that bad and i want my truck to be different, it seems everyone on this site has 33" tires :notsure::crapstorm:
  2. Jan 12, 2012 at 2:06 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    What would it do if i dont?
    Should i just put dana 60s in or regear, im not really good at toyota stuff
  3. Jan 12, 2012 at 2:08 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    How much would it cost to regear? Would 5:29s be good?
  4. Jan 12, 2012 at 2:11 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    So you recomend that i regear
  5. Jan 12, 2012 at 2:13 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    So i would need around 4:56 ratio for 35" tires?
    Would i be able to do the regear in my garage or would i need to take to a mechanic
  6. Jan 12, 2012 at 2:14 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    That chart says my Tacoma with stock everything is "more power". So I would put too much weight on that charts "facts"
  7. Jan 12, 2012 at 2:15 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    Ive regeared danas and rockwells before... Are tacoma axles different?
  8. Jan 12, 2012 at 4:05 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    I would re-gear to at least 4:88. Some people prefer 5:29. I personally re-geared to 4:88 in anticipation of 35s, im still on 33s so it kinda sucks on the interstate. ECGS is a great way to re-gear, they send you a pre-built diff with the gears already set up and you send yours back. Pretty easy, this is the way i went. As far as a BL, I would say stay away. It is probably going to rub anyway, so just tub the firewall and skip the BL. No need for it, your probably going to have to tub anyway so just do it without the BL. I am getting mine off as soon as I can.
  9. Jan 12, 2012 at 5:25 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    the chart is a little low on the gears... 4:56 for 33's and 4:88 for 35's
  10. Jan 12, 2012 at 5:29 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    4.88 for sure.
    You'll be super sluggish with that automatic and 35's if you don't regear.
    East coast gear supply is a great way to go.
  11. Jan 12, 2012 at 7:50 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    skip the shitty body lift and just tub the front fender wells if you want to run 35's.
  12. Jan 13, 2012 at 12:17 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I would still run a 4 crawler 1" BL
  13. Jan 13, 2012 at 8:16 AM
    Rebel Taco 22
    Why?
    You dont need it to fit the tires. You can still tub for 35s and have no trouble fitting them without the BL.
  14. Jan 13, 2012 at 8:28 AM
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    I have 4.56 with 33's. It's a good combo, stock... maybe a lil more then stock power. I think it would be ok if I stepped up to 35's, but I would much rather have the extra get up and go of a 4.88.
    x10 on ECGS great guys to deal with!
  15. Jan 13, 2012 at 10:52 AM
    Rebel Taco 22
    I guess if you dont want to cut the floor you could get a BL. Im taking mine off and when I do decide to get a crawler and 35s, ill be cutting.
  16. Jan 13, 2012 at 11:41 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Just that much less cutting for the tires. also I believe you can clock the T-case a bit more if you put a body lift on.
  17. Jan 13, 2012 at 2:42 PM
    Rebel Taco 22
    I see it as, your already gonna be cutting so why not cut a little more to avoid the BL? It has been done multiple times. GOTCOPE? on ttora runs a 1'' BL and tubbed the firewall and fits 37s. If he took the BL off, he would have to run 35s.
    Just saying, run the BL if you want to. Hell you can have mine when i take it off in a month or so.
  18. Jan 17, 2012 at 5:21 PM
    livnlrn
    livnlrn Well-Known Member
    Rick
    Elkton, Virginia
    2009 TRD double cab
    I have 488's with 35's. 5 speed with 6cyl. Gears are perfect. Good take off & runs well on the interstate ( as long as u run under 80 )
  19. Jan 18, 2012 at 5:20 PM
    Tacoma mud
    Kyle
    TEXAS
    soon to come
    Hmmm well is their a guide to tub the firewall cuz itll be the first for me.
    And itll cost around 1000 to regear? Less? More?
  20. Jan 18, 2012 at 6:10 PM
    livnlrn
    Rick
    Elkton, Virginia
    2009 TRD double cab
    If u pay someone to install them, then yes, prob. $1000.
