do i let it warm up????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xtirtzt, Jan 14, 2009.
  1. Jan 15, 2009 at 7:52 AM
    #41
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    Only takes about 10 seconds for the oil to circulate. Idling is the hardest thing an engine can do. Letting it warm up for an extended period of time just promotes carbon build up.
  2. Jan 15, 2009 at 7:53 AM
    #42
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Alway let your truck warm at least 5 min. when its cold if not you run the chance of CRACKIN! the block. In warmer weather turn it on get the oil moveing and drive off.
  3. Jan 15, 2009 at 7:55 AM
    #43
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Had -14 temp on the center console today going to work with -40 windchills.
    But my tech is, below 0 here and its a 10 min warm up. Above 0 its get in and a slow crawl till the engine revs down and then on the gas to get her warmed up. Damn windows fog like hell though with recirculate on, get some outside air and it slowely goes away..one of my biggest pet peeves with this truck.
  4. Jan 15, 2009 at 7:56 AM
    #44
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have heard the rumors, but this has never been confirmed. The coolant and oil in the engine is going to prevent this from happening.
  5. Jan 15, 2009 at 7:58 AM
    #45
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Welcome to TW, Air force brat?
  6. Jan 15, 2009 at 7:58 AM
    #46
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I always let it warm up in the cold weather. If its near 40 or above - I'm not concerned too much about letting it warm up. Depending on if I'm running late or not - I usually let it warm up about 5 minutes. My truck is parked outside all the time.
  7. Jan 15, 2009 at 7:59 AM
    #47
    Jester243
    Dan
    Spokane, WA
    I usually let it warm up a coupel of minutes while I have a quick smoke.
  8. Jan 15, 2009 at 8:05 AM
    #48
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    Yeah, Air Farce brat, both parents no less.
  9. Jan 15, 2009 at 8:20 AM
    #49
    Jester243
    Dan
    Spokane, WA
    I am too, well just my Dad, we were in Minot for 4 years, ugh!!
  10. Jan 15, 2009 at 8:21 AM
    #50
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Apparently there was a problem in the late 1990's into the early 2000's with some cast iron block diesel engines in commercial trucks. Some of the blocks were improperly cast leaving voids which caused poor heat transfer and weak areas. Unless you've dropped a Cummins 5.9 liter diesel into your Tacoma you don't have to lose much sleep worrying about this.
  11. Jan 15, 2009 at 9:03 AM
    #51
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    Excellent post. I was reading through the thread and wondering why nobody suggested an EBH (engine block heater). I had an EBH installed in my Taco by the dealership when I bought it, it wasn't very expensive, parts and labor totalled around $100 if I recall correctly. I plug it in at night and in the morning, depending on how cold it gets, the oil temp (per the ScanGaugeII) is around 80F. I start the truck and drive away.
  12. Jan 15, 2009 at 9:09 AM
    #52
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    Yep, is sure is cold here in the NorthEast too., though not as cold as Wis, Minn etc. I had to go out at 8am and it was 6deg her in Mass. I just fire it up let it warm up for a min or two, as I had to leave, then drove just normal, no lugging, shifting around 1800rpms until the gauge got off the bottom.
    Had I had plenty of time I would have waited until the temp gauge got up a little and the idle settled down.
    Thats one of the good things about syn oil, it stays fluid at very cold temps.
    Tonite, it will be -1 or -2 and the wind will pick up tomorrow, that of course does not effect engines, just exposed skin.
    Jeff, 06,V6, 6spd, 4x4 Radiant Red
  13. Jan 15, 2009 at 10:04 AM
    #53
    sonjay
    sonjay Well-Known Member
    I've experienced starting or trying to start diesels in cold. Doesn't sound good especially Ford power strokes. Running on 2 then 3 then 6 cylinders. This is at -30-40c. A lot of guys where I was in Fort Mac would start the truck and put a brick on the throttle to warm them up, ugly sounds! When it was really cold for a couple weeks, we didn't shut anything off, run all day all night at 1000rpm. Stick a jug of your motor oil outside when its cold and try and pour it in the morning, yes synthetic is better then conventional oil, but it's still like molasses when its cold. I think it's all going to depend on the overnight temps in your area, and weather you park outside. If I parked in a garage I wouldn't let it warm up much.
  14. Jan 15, 2009 at 10:39 AM
    #54
    sweater914
    North Dakota
    Well, there's nothing magical about Minot, except when it's cold enough you can take a glass of boiling water and toss the water outside it immediately turns to ice crystals.
    For those of you living in the tundra, I highly recommend an oil pan heater. They come in different shapes/sizes to fit various applications, usually broken down into how much oil is in the pan. Different vendors offer them about the pads are 3M products. My Ranger didn't have a block heater so the oil pan heater was the easiest install. My wifes F-150 has both and before she gets to the end of the block she usually has heat.
    As far as folks having their blocks crack I wouldn't know, but if it were a problem it would be an epidemic in North Dakota.
    I run Amsoil in all my vehicles 0W-30, even at -40 the viscosity is still very low(high?). Before the major advances in motor oils even conventional dino oils some very old manuals advised the user to dilute the oil with gasoline. Sounds nuts but given the tolerances of 50-60's era engines and poor oil viscosities this was only way to have the oil flow before your engine siezed (PLEASE DO NOT ATTEMPT ON YOUR TACO, FOLLOW YOUR OWNER'S MANUAL). Once the engine reaches operating temperature the gasoline would evaporate. I'm sure the hydrocarbons coming out the tail pipe were just a little more than today.:)
  15. Jan 15, 2009 at 10:40 AM
    #55
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yes.
    Had that happen in Slave Lake when it was -50ºC and a windchill on top of that. One of the other medics plugged her Diesel into a faulty plug which wasn't working and froze her truck solid. Took me 3 hours to get it to start again. Let's just say that truck hates life now.
    Other times yeah, we just had to leave them going all the time cause if you let it stop and cool down, it will never get started again unless you want to try ether. But I don't know if that even works with diesels? I know you can do it with petrol.
  16. Jan 15, 2009 at 10:59 AM
    #56
    sonjay
    I was in Anzac for a while and before that we were in the Slave lake area! On the DND base or some base? Ether or nose candy works with old diesels, most new diesels have glow plugs, or some sort of intake heater which could ignite the ether and cause harm to the engine and you. We had one truck with a big Cat and it had a oil heater and big 2000w block heater, and no go would not start. We ended up leaving the steam wand under it for a couple hours.
  17. Jan 15, 2009 at 11:03 AM
    #57
    81shark
    81shark Well-Known Member
    or run it off a temp guage like it should be if you were putting in an electric fan.
  18. Jan 15, 2009 at 11:09 AM
    #58
    81shark
    circulate the fluids? the oil is circulating from teh get go, the coolant is going anywhere until it heats up enough to open the t stat to head to the radiator. transfluid? that doesn't move unless the car is moving...at least in a manual. i suppose with an auto it is a little.
    just fire it up and go. that's what you are suppose to do.
  19. Jan 15, 2009 at 11:29 AM
    #59
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    When its cold out i let my truck warm 'til it either thaws the ice off, or if there isn't any I still wait until the SG reads about 80 deg. temp. With the cold my 6speed is almost impossible to get into 1st until driven and warmed up a bit so thats some motivation to let it warm up a bit too.
  20. Jan 16, 2009 at 5:26 AM
    #60
    Jeff
    Hopkinton,MA
    The original part of this thread was discussion on Taco's being warmed in "normal" cold temps and morphed into diesels in the artic and very extreme temps.
    I am surprised not to hear that more Taco owners( or any car/truck owner) in the colder climates, such as Wis, Minn. or even the upper regions of Vt., Maine and NH., don't have block heaters etc. Certainly would help and make the warm up quicker.
    Those area's that have below 0 for many days in a row definately benefit from extra help. Luckily this morning its only -2deg...
    Jeff , V6, 06, SR5, 6spd, 4x4
