do I need a 1/4" top spacer???
Discussion in 'Suspension' started by w103tws, Nov 29, 2010.
  1. Nov 29, 2010 at 5:47 PM
    w103tws
    w103tws [OP] Well-Known Member
    I've got the billies, and am planning on setting them at 2.5. I have the 2" AAL. I also have some 7089's. As of now, I'm planning on going with 285/75/16's.
    Will I need to get the 1/4in top plate on top of my billies in order to run the 285's? I know the tires will fit, it's just will adding the spacer require less trimming? Also I don't plan on doing UCA's anytime soon. I don't wanna F' anything up, so will I be ok?
  2. Nov 29, 2010 at 5:49 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Your gonna rub most likely without a spacer. Are you on stock coils?
  3. Nov 29, 2010 at 5:52 PM
    w103tws
    yeah, stock coils. So, you think I won't rub with the spacer then?
  4. Nov 29, 2010 at 5:53 PM
    w103tws
    My initial intentions were just to use the billies to level it out and run 265's, but then started to fall in love with the pics of trucks with 285's and figured I could just do the above, and run that size.
