Do I need a 4x4??
Discussion in 'Toyota Trucks & SUVs' started by thconartist, Nov 23, 2013.
  1. Nov 23, 2013 at 8:22 PM
    thconartist
    thconartist [OP] New Member
    For a first vehicle im most likely going to buy an Xtra cab taco. For a while I was under the influence that I was going to need a 4x4, but after looking online for a bit I started looking at prerunners because of the insurance and fuel savings.
    Im trying to decide between a 98-03 v6 4x4 and a 98-03 v6 prerunner with locking differential.
    Where I live I get a few feet of snow in the winter, and I will be going up the ski hill every weekend, thats the extent of driving I'll be doing, no major offroading.
    Do you guys think I'll be fine with a prerunner, or should I get the 4x4?
  2. Nov 23, 2013 at 8:24 PM
    Colt562
    Colt562 Well-Known Member
    Brett
    SoCal
    13' TRD Sport 4x4
    Icon Stage 3 Lift Kit...Dakars
    get the 4x4.
    My insurance went up 10 dollars when I got my 4x4.
  3. Nov 23, 2013 at 8:37 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    If you have to ask the answer is yes.
  4. Nov 23, 2013 at 8:42 PM
    bzzr2
    bzzr2 Well-Known Member
    4x4 absolutely, snow and hills in a 2wd are less than pleasant at times where with the 4x4 life is simple. finally got snow here today, needed 4x4 to get out of my driveway that has a slight angle! i've only had one 2wd truck and with good snow tires and weight in the bed behind the axle it was barely acceptable in hilly terrain in my opinion during snowy conditions.
  5. Nov 23, 2013 at 8:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    '98-'03, insurance difference is going to be minimal.
  6. Nov 23, 2013 at 9:08 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    4x4, better to have it when you need it.
  7. Nov 23, 2013 at 9:11 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    4x4 all the way
    i used to have a 95 5 lug access cab, and i just recently got my 03 DC 4x4, the only thing i miss about my 95 is the manual trans.
  8. Nov 23, 2013 at 9:13 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes
  9. Nov 23, 2013 at 9:14 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    gas mileage with a truck is already going to suck. there's a negligible difference between the prerunner and the 4x4. there isn't much additional maintenance either.
    edit: "get the 4x4" is my point, in case that wasn't clear. :)
  10. Nov 23, 2013 at 9:28 PM
    Manwithoutaplan
    ID
    yes period.
  11. Nov 24, 2013 at 8:09 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    The worst vehicle you can drive in the winter is a 2wd truck. Of course get the 4wd
  12. Nov 27, 2013 at 9:31 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Or a motorcycle..
    But yeah, 4wd for sure.
  13. Sep 21, 2014 at 7:40 PM
    hutch463
    hutch463 New Member
    Hutch
    Eastern NC
    '98 Tacoma Xtra Cab 4x4
    Here in eastern NC, I rarely use my 4WD (unless I get the chance to go wheeling locally, which is very rare). I have found, however, that when I need my 4WD, I really NEED my 4WD. My first Toyota truck happened to be 4WD, and I WILL NOT go without it. You'd be surprised at the things you can use 4WD for. It really does come in handy for things besides wheeling and inclement weather - so, along with everyone else that has replied, YES, GET THE 4x4!!!!!!
  14. Sep 21, 2014 at 7:41 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Welcome to TW. This thread is almost a year old, though. :)
  15. Oct 22, 2014 at 5:36 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Need has nothing to do with it.
  16. Oct 22, 2014 at 5:37 PM
    OZ-T
    Peter North
    British Columbia
    Yes , you need a 4x4
  17. Oct 22, 2014 at 5:38 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  18. Oct 22, 2014 at 5:53 PM
    stombs
    stombs Well-Known Member
    Scott
    New Jersey
    2013 Tacoma V6 4x4 Access Cab TRD sport
    weather techs, westin grille guard, cb radio
    I drive my tacoma through snow in 2wd without an issue never once came close to sliding but I like to have 4x4 on just for safety. What my brother said to me "Its better to have it and not need it then not have it and need it"
  19. Oct 22, 2014 at 10:33 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Snow is not the only reason to have 4WD!
  20. Oct 22, 2014 at 10:36 PM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    I fixed your question and Yes.
    Long answer: I hade a 2007 toyota tacoma prerunner I asked my self the question should I get a 4x4? ended up trading in the truck losing some money for not saying yes in the first place just get it and save yourself some money.
