Do I need a diff drop kit?
Discussion in 'Suspension' started by thedahl, Dec 26, 2012.
  1. Dec 26, 2012 at 7:14 PM
    thedahl
    thedahl [OP] Member
    Canada
    12' TRD
    I am about to install my 5100's on my 2012 DCLB TRD set at 1.75 and I'm wondering if I need to purchase and install a diff drop kit. I have done a ton of reading on this site and many others but I cannot find a definitive answer. The biggest answer I found was that anything over 3" you need the drop kit. Is this accurate? I just want to ensure I'm doing the right thing. Any info would be greatly appreciated!
    Thanks.
  2. Dec 26, 2012 at 7:21 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  3. Dec 26, 2012 at 7:33 PM
    DSYLEXC
    DSYLEXC Well-Known Member
    Just installed a Icon Stage 4 suspension on my 2012 and it gave me between 2 1/2 - 3" of lift, no diff drop, and no issues at all. No vibrations.
  4. Dec 26, 2012 at 7:40 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    If the fins on your CV boots aren't touching (they shouldn't at 1.75" lift), then no action needed.
    If the fins are touching, simply undo the clamp, slide the boot further down the shaft to space out the fins, then re-tighten the clamp.
  5. Dec 26, 2012 at 8:18 PM
    thedahl
    thedahl [OP] Member
    Canada
    12' TRD
  6. Dec 26, 2012 at 8:20 PM
    thedahl
    thedahl [OP] Member
    Canada
    12' TRD
    That's what I wanna hear...thanks.
    Ya, I don't think that they'll be touching at only 1.75 so I think I'll be in the clear. Thanks.
  7. Jan 14, 2013 at 10:18 AM
    CajunBug73
    CajunBug73 Member
    Paul
    Milwaukee, WI
    2011 Tacoma 4x4 Base Single Cab
    Wassup bud!
    I just got a 1.75 lift with Bilstein 5100's and 1 1/4 increase in rear. Got them done on Jan, 5, 2013. I get a very slight vib from the front; not sure what the fins are on the CV boots (very new to these things), could use some great advice! Thanks :)
  8. Jan 14, 2013 at 11:58 AM
    rawdog
    rawdog Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    If you look under your truck, look where the wheel connects to the truck, there should be a shaft there that connects your wheel to the differential. Where the shaft connects to the diff, there is a black rubber boot. You cant miss it.
    The fins are the folds in the boot, if they are touching anywhere while on flat ground then that means that they are rubbing.
  9. Jan 15, 2013 at 11:42 AM
    CajunBug73
    CajunBug73 Member
    Paul
    Milwaukee, WI
    Thanks my man....just checked under the front end and from what I can see, none of the fins are touching at all. Judging by your photo with the bottom of your boot, my fins are a lil bit farther apart on the bottom, so there almost equel distance on the top and bottom, so that should be fine and no need for diff drop? Thanks in advance. (thank god they are tacos)...love em!
  10. Jan 16, 2013 at 8:51 AM
    CajunBug73
    CajunBug73 Member
    Paul
    Milwaukee, WI
    what happened?
  11. Jan 16, 2013 at 9:58 AM
    rawdog
    Kelowna B.C.
    That pic is actually just from google images haha I was too lazy to go take a pic of my piece of junk. But it's the pretty much the same on our trucks.
    I would say, that if your boots are not rubbing while on regular ground, you probably don't need a diff drop, however, that being said. Less CV angle is always better but if you don't want to spend the extra cash I wouldn't worry too much about it.
    I never put one in my 2.75" front spacer.
