Do I need a harmonic balancer installer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hothead, Jul 29, 2024.
  1. Jul 29, 2024 at 7:35 PM
    Hothead
    Hothead [OP] Active Member
    I read that Toyota's 1GRFE aren't pressed on, and should slide right on without an installer tool. Is that true? Same with removing, will I need a remover to take it off. I can't find a definitive answer.
    Thanks.
  2. Aug 1, 2024 at 12:20 PM
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    It isn't a tapered fit. I've gotten them to slide off with no tools. If there's the chance it is rusted, might not be a terrible idea to have a puller on hand. You will need the special tool to counter hold the sprocket while removing or installing the bolt. If you have a 6MT, you can just drop it in low range, set the brake, and use the driveline to hold it in place.
  3. Aug 1, 2024 at 10:02 PM
    Hothead
    It just slid right off. After breaking a breaker bar and impact socket, and using a 900 ftlb and 1500 ftlb impact with no luck. The new breaker bar with a short socket and engine bump did it. 3 hours for one bolt. What a PITA. And I have auto, so I’ll have to make a holder to torque it back down.
  4. Aug 2, 2024 at 6:42 AM
    VoodooBlueATL
    2007 FJ Cruiser
    When I did mine, my 600 ft-lb air impact zipped it right off with no issues at all.
  5. Aug 2, 2024 at 7:29 AM
    zguy1
    zguy1 Well-Known Member
    Midwest
