Do I need a hitch pin?
Discussion in 'Towing' started by ziggynagy, Oct 15, 2013.
  1. Oct 15, 2013 at 2:36 PM
    ziggynagy
    ziggynagy [OP] All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Sorry for the newb towing question...
    Just got a D-Ring receiver and don't have a hitch pin. I do have a 5/8 stainless steel bolt, could I just throw on 2 washers and a nut? Or is there something special about hitch pins that I'm missing?
  2. Oct 15, 2013 at 2:37 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    hitch pins are made to take on and off easily, id just go buy one.
  3. Oct 15, 2013 at 2:41 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    and most are made so the hitch dose not slide in and out to much, and are probably stronger than a bolt.
  4. Oct 15, 2013 at 2:45 PM
    mudyota
    mudyota Japanese
    eastern NC
    TRD offroad yota
    They are made to come off easy...so people can steal them haha
    I've had some really nice hitches with hitch pin locks stolen by cutting the lock with a hack saw blade
    Of course my truck is lifted so I have to get a nice drop hitch and robbers can't stay away so I just keep it in my truck
  5. Oct 15, 2013 at 2:47 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    I'd get a pin, you don't want much play in there and pins are made for hauling. Probably a lot stronger and harder than just a bolt.
  6. Oct 15, 2013 at 3:07 PM
    PattonT
    PattonT Well-Known Member
    2013 2.7l prerunner
    As long as that bolt is not zinc, but grade5 or grade 8 you will be fine. Without getting into specifics a 5/8" grade 5 in the shank is actually as strong as a 5/8" hitch pin.
  7. Oct 15, 2013 at 4:50 PM
    ziggynagy
    Stoughton, MA
    Til I do some research, I'll have to take your word on that.
  8. Oct 15, 2013 at 5:42 PM
    PattonT
    2013 2.7l prerunner
    5/8" grade 5 bolt is about 25,000 sheer strength and grade 8 is about 27-30k (depending on threads)in tensile strength. For a hitch pin where you aren't clamping down when tightening Grade 5 may fair better. Truthfully they would be almost the exact same for a hitch pin. Most hitch pins are only rated at 10k very conservatively.
    Make sure the bolt is long enough that the threads are not riding the metal of the hitch.
