Do I Need A Lift...I Want 285/65/18 Nitto Terra Grappler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Logan22, Jul 30, 2011.
  1. Jul 30, 2011 at 6:19 PM
    Logan22
    Logan22 [OP] Well-Known Member
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Tonneau Cover, Tube Steps, Kenwood Excelon KDC X895, Boston Acoustics Speakers, 12 Shallow Mount Rockford Fosgate punch p3s sub, Rockford Fosgate Punch 400 watt amp 18 in. xd spy's 285 60 18 terra grapplers
    I have a 06 tacoma trd 4X4 double cab and it is stock. I really want to get 285/65/18 with Nitto Terra Grappler's and would love to do this without a lift and without any issues with rubbing anywhere. More than likely I am going to get bilstein 5100's all the way around and I would like to leave them set at 0. If i need to get coils I would get eibach, but thats only if I would need a small lift. I only offroad when hunting and that is just going through some feilds and driving down a bumpy dirt road at a slower speed, so not very much offroading at all. I mostly just drive on the road. I dont want to rub anything when going over bumps on driveways or on the road. Do the bigger tires make a difference on the accuracy of the speedometer and the mpg.? Also will the ride quality be different? Some people say that bigger tires and wheels have made their truck wander on the road at high speeds, will it make the truck do this? The reason I am asking this is because some people say this set up will work with no lift and some say it wont. I want no lift or just a small lift to make this work. Any idea of what the bs on the wheels would have to be? Sorry for all the question's...any help is greatly appreciated.
  2. Jul 30, 2011 at 6:21 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Yes
  3. Jul 30, 2011 at 6:21 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    x2
  4. Jul 30, 2011 at 6:22 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Most definitely you will
  5. Jul 30, 2011 at 6:23 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you will need a lift and even then you may rub.
    the max you could probably do without a lift is 275/65 18
  6. Jul 30, 2011 at 6:23 PM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Yes. You are gonna rub the front inner liner and when you turn you will rub on the cab mount. Best bet is to get a lift
  7. Jul 30, 2011 at 6:26 PM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    How much of a lift?
  8. Jul 30, 2011 at 6:28 PM
    Brandon H
    Newhall, CA
    07 DC Offroad
    I would say 2.5. It all depends on what u are gonna do with the truck. Off road, street, etc.
  9. Jul 30, 2011 at 6:36 PM
    Swanson52
    Swanson52 Well-Known Member
    Seems like I've seen this question before somewhere...
  10. Jul 30, 2011 at 6:37 PM
    fsbrain03
    fsbrain03 Well-Known Member
    Yes, and cut!
  11. Jul 30, 2011 at 6:40 PM
    OZ-T
    Peter North
    British Columbia
    OP you can fit 265/75/16 without lifting
  12. Jul 30, 2011 at 6:41 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Zach
    Oregon
    x3 or you can do some major trimming...
  13. Jul 30, 2011 at 6:42 PM
    04LTtacoma
    Zach
    Oregon
    The OP wants 32" tires...
  14. Jul 30, 2011 at 6:54 PM
    OZ-T
    Peter North
    British Columbia
    I know that , but he also said he doesn't wanna lift
  15. Jul 30, 2011 at 6:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A 265/75/16 is a 32" tire....
  16. Jul 30, 2011 at 6:57 PM
    04LTtacoma
    Zach
    Oregon
    ^ I don't think so Chris4x4. I am pretty sure a 265/75/16 is a 31" tire.
    285/75/16 is a 32" tire
  17. Jul 30, 2011 at 6:58 PM
    OZ-T
    Peter North
    British Columbia
    265/75/16 is 31 1/2 to be exact
  18. Jul 30, 2011 at 6:59 PM
    04LTtacoma
    Zach
    Oregon
    Ok, so we were both right... lol
  19. Jul 30, 2011 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This ^^^ Clasified as a "32" Tire". A 265/70/16 is a 31" tire, and a 285/65/18 is a 33.......
  20. Jul 30, 2011 at 7:07 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
