Do I need a major trim to fit 285/70R17?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blacktaco2022, Jan 21, 2023.
  1. Jan 21, 2023 at 6:41 PM
    blacktaco2022
    blacktaco2022 [OP] Member
    Texas
    So I am getting a 3 inch front and 2 inch rear lift. Also getting the Nitto LT285/70R17 Trail Grappler with the SSW off-road Dakar 17x9 -25 offset and I’m wondering will it fit good with minor plastic trim or do I have to do a major metal trim?
  2. Jan 21, 2023 at 6:43 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Check in the suspension stickies.
    I think someone has already posted something similar that might help you.
  3. Jan 21, 2023 at 7:06 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    From all the threads I have read, get ready to do some major cutting, hammering, and most likely cab mount chop. You should consider UCA's and needle bearing replacement with clam shell. Advisable with anything over 2" lift.
  4. Jan 21, 2023 at 7:23 PM
    Redfive11
    Redfive11 Well-Known Member
    La Mirada, CA
    2012 PreRunner
    FOX 2.5 EXTENDED TRAVEL w RESI /DSC CAMBURG UCA PELFREYBILT HYBRID FRONT BUMPER
    Use the search function and read up. You will rub. That offset will make it worst. You will most likely need a CMC.
  5. Jan 21, 2023 at 7:39 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    If you get the offset right, there won't be major rubbing. Some rubbing is to be expected
  6. Jan 21, 2023 at 7:53 PM
    Metric Rider
    Metric Rider Well-Known Member
    Gar
    Valley Farms, AZ
    2017 Tacoma TRD Sport
    Body Armor Front Bumper, Smittybilt XRC 9.5 GEN2 Winch, Fab Fours rear bumper, 400 watt inverter anytime, Front camera, On-board ARB air compressor.
    I'm running BFG 285/70R17 K02's on stock 2017 wheels, have a 2 1/2" lift all around and a Body Armor front bumper. No rubbing anywhere. Your neg wheel offset may cause you some issues at the fender corner on the front.
