Do I need a new transmission?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rob02, Mar 3, 2023.
  1. Mar 3, 2023 at 3:01 AM
    Rob02
    Rob02 [OP] New Member
    Robbie
    Hey guys, first post here so apologies if this is posted in the wrong place. Anyways, I have a 2006 4.0 double cab prerunner with the 5 speed auto with 267,000 miles. I recently drove it down from Salt Lake UT to LA and the trip was uneventful. However while driving in LA, I hit the gas and then the truck would barley accelerate for 5 seconds like a clutch slipping on a manual before seeming to “grip up” and the truck pulls real hard and rips through the gears. This is not a steep incline thing as it was happening on flats and even slight downhills like when I was getting onto the onramp on the freeway. However, it also would not go into 5th gear and hovered around 3k rpm in 4th gear. While this was happening I herd multiple loud clanking sounds seeming to come from the transmission. ( the truck not wanting to shift into 5th has happened multiple times in the past but none of the other aforementioned symptoms occurred) I thought I definitely need a new transmission but when I went to drive it today, none of the problems mentioned above were present and it seemed to be perfectly fine. I have to make the 600 mile trip back and I’m worried it’s going to act up leaving me stranded with an expensive tow bill. Any ideas on what i should do? I’ll gladly put in a used transmission, but want to make sure it is in-fact a transmission problem that would warrant replacing the whole thing. The drive shaft also snapped about 1,000 miles ago and I had it rebuilt with zero issues since. Sorry for the long read, just want to be clear on what is going on.
    Ricardo13x likes this.
  2. Mar 3, 2023 at 4:59 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Quick: when its hot pull the fill plug on side (not the drain) and see if its low (insert finger if none comes out) and add till its full.
    Or get the dealer or a shop to do a full exchange of all fluid as about 3 in pan and 10 in converter.
    Many on TW don't like the full exchange and many do. I had dealer do it and shifted better and stronger 5th gear torque converter lockup.
    There are some internals that can get gummed up but I would try above first as quick and easy. Full exchange was low 200s but probably went up as everything did.
  3. Mar 3, 2023 at 5:07 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    ^ Have a professional check the problem (along with the fluid level).
    Dm93 likes this.
  4. Mar 3, 2023 at 5:55 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That's not the procedure to check the fluid level, for the proper fluid check see the thread below but note the check temperature was changed from what the thread states to 95-115F.
    But I do agree the first thing is to check the transmission fluid level and condition.
    https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
  5. Mar 3, 2023 at 8:36 AM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    If you need a transmission (A750E) I have one that I’m ok to let go for cheap. Dm me any questions. It was pulled from my truck fully functional.
