Do I need an alignment after new front shocks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by knayrb, May 12, 2016.
  1. May 12, 2016 at 7:55 AM
    knayrb
    knayrb [OP] Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I intend to replace my front shocks. According to official Toyota instructions, I need to remove the ball joint. After putting everything back together, will I need to get an alignment done? I trying the cost difference of having someone else do it or doing it myself. Thanks.
  2. May 12, 2016 at 7:57 AM
    Iasco
    Iasco Well-Known Member
    Yes
    Arailt likes this.
  3. May 12, 2016 at 7:57 AM
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
  4. May 12, 2016 at 8:16 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Maybe things are different on a 2010. What official Toyota instructions are you referring to?
  5. May 12, 2016 at 8:24 AM
    dantrd05
    dantrd05 Well-Known Member
    Daniel
    Ottawa, ON, Canada
    2016 DCLB TRD Sport
    BF KO2 with FN Fx Pro's (Matte bronze) Levelling kit 2,75" Front and 2" Rear.
    Yes you do!
    If it's like the 3rd gen, you need to remove the lower ball joint (or ball joint bracket) in order to push the lower control arm down to make room to remove the strut assembly. In order to push the control arm down, you need to loosen the control arm bolts (Do not remove them).
    When you play with all that stuff, it's always HIGHLY recommended to do an alignment. It's a well invested 75$ that can save your tires.
    spitdog likes this.
  6. May 12, 2016 at 9:23 AM
    knayrb
    Bryan
    Pure stock
    So I'm at work and don't have my same browser bookmarks as at home. A while back someone posted the factory Toyota Manual link and I know it's on this site somewhere. (Maybe someone will post it again before I get home tonight). I've been unsuccessful hunting it down. I was worried it would disappear due to copyright issues and so I installed the Firefox add-on, Downloadthemall!, https://addons.mozilla.org/en-US/firefox/addon/downthemall/, and pulled every PDF to my HD. I then copied the main index html page to my HD and did a global change to all links pointing them to my HD files instead of the online PDF. Now I have a directory on my HD with a html link that points me to hundreds of PDF files out of the manual. I just print the one I am working on and take it to my garage when needed. I'll post the link tonight if someone doesn't beat me to it.
  7. May 12, 2016 at 9:40 AM
    Lester Lugnut
  8. May 12, 2016 at 9:42 AM
    Maximus
    Maximus Well-Known Member
    North Bay
    11 Tacoma TRD OR 4x4
    Icon Suspension with CDCV, SPC Light Racing UCAs, Wheeler's 3 Leaf AAL, Wheeler's Superbumps, sPod SE BAMF Sliders, All-Pro Skids, AFE Drop in filter, Magnaflow Exhaust, RCI Aluminum LCA Skids, BAMF Bed Brackets, 4X Innovations Rear Bumper, FX-R Retrofit Headlights with Philips 4300k, Custom Nestah Edition Firestik AM/FM Antenna, Famous Fab Hood brackets, FrontRunner SlimLine 2 Roof Rack, Mob Town Offroad tailgate reinforcement plate, Ram A pillar mount, Anti-Dark hood lights, Lots of LED lights,
    Yes. I just installed new coilovers and UCA's. Although the truck drives straight, I will still be getting an alignment as soon as I get this squeak from my UCA sorted out.
  9. May 12, 2016 at 9:42 AM
    SethB
    SethB Well-Known Member
    TDY
    **SOLD** 2009 DCLB 4X4 Auto
    OME Suspension, SPC UCAs, ARB Bumper, Smittybilt Winch, Ext Brakelines, SOS Sliders, 4x Innovation Rear bumper
    You don't need to remove the BJ to swap out springs/shocks. Look in the suspension section, it's all stickied. You unbolt the coilover, pry down the LCA and maneuver it out.
    You also won't need an alignment most likely if you leave it at stock height, although most do it just to dbl chk.
    fla_sun likes this.
  10. May 12, 2016 at 9:56 AM
    knayrb
    Bryan
    Pure stock
    Great, you had the link I was talking about. I was a little off. It's the Tie Rod Assembly that I was referring to. That is mentioned in step 8 on this page and is shown on this page.
    So it sounds like it would be best to get an alignment. Probably so since I have only 5K miles on my Michelin AT2 tires.
    Thanks.
