Do I need an extended brake line w/OME Dakar+AAL?
Discussion in '1st Gen. Tacomas (1995-2004)' started by danthaman, May 6, 2016.
  1. May 6, 2016 at 7:11 PM
    danthaman
    danthaman [OP] Well-Known Member
    Daniel
    San Ramon, CA
    1999 Xtracab V6 TRD 4x4
    OME 882 W/Dakar+AAL 285/75 Dynapro ATM
    I am going to be throwing on ome dakars and bilstein 5125's on my truck next week. Are extended brake lines necessary?
  2. May 7, 2016 at 6:07 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Depends on shock length. With the 8.5 5125s you may get by for a bit but if their longer then definitely. Just spend the $40 and have no worries.
  3. May 7, 2016 at 8:39 AM
    McMash
    McMash The only thing better than light bars? Sarcasm.
    Tyler
    Gig Harbor, Wa.
    '04 Tacoma AC TRD 4x4
    As Devin said, it depends on what shocks you're running. I have the Dakar with the extra load leaf, and run the suggested Nitrocharger Sport shocks. I bent down the brake line bracket on the frame for an easy 1-2" of extra slack and even at full droop, the lines aren't being stressed.
    The Nitrochargers are definitely acting as limiting straps, so if you're running anything longer then I would say an extended brake line is required.
  4. May 7, 2016 at 2:10 PM
    danthaman
    Daniel
    San Ramon, CA
    Alright thanks guys!
  5. May 7, 2016 at 2:11 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    It would be a good idea! Plus the ss lines help with pedal feel quite a bit.
