Do I need conversion harnesses for Morimotos XB led headlights?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sauhcee, Jul 20, 2023.
  1. Jul 20, 2023 at 10:10 AM
    sauhcee
    sauhcee [OP] Member
    Hello, I own a 2017 trd off road tacoma and recently purchased the 2016-2022 Toyota Tacoma XB LED Headlights. Do I need any type of harnesses or is it complete plug n play ?
  2. Jul 20, 2023 at 10:13 AM
    Tacospike
    Two Trucks
  3. Jul 20, 2023 at 5:56 PM
    eminence978
    eminence978 Well-Known Member
    Plug and play I have it on my truck
    my.taco likes this.
  4. Jul 20, 2023 at 5:57 PM
    sauhcee
    sauhcee [OP] Member
    same model / trim ?
  5. Jul 20, 2023 at 6:04 PM
    my.taco
    my.taco Well-Known Member
    2023 TRD OffRoad, Lights, skid plate & Side bars.
    These the headlights with the built in LED's that can't be changed ? If so, arn't you guys worried one will fail, then you'll have to change the whole headlight unit to get lights working ? Makes more sense to buy headlights with changeable led's ?
  6. Jul 20, 2023 at 6:04 PM
    eminence978
    We both have the factory led drl so it should be the same. I have a sport trim
  7. Jul 20, 2023 at 6:40 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    No such thing for the Tacoma. Drop in LED bulbs are hot garbage.
    Chew and TRDRed like this.
  8. Jul 20, 2023 at 6:41 PM
    my.taco
    Go on ...
  9. Jul 20, 2023 at 6:41 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
  10. Jul 20, 2023 at 6:42 PM
    USPfan
    USPfan Well-Known Member
    North of 60th paralell
    2018 Tacoma TRD OR DCSB
    I have the Morimotos on a 2018 Off road. No harness needed. They word just fine.
  11. Jul 20, 2023 at 6:43 PM
    my.taco
  12. Jul 20, 2023 at 6:44 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Congrats on lowering the lighting performance of your truck. Did you even read the thread?
    Chew, tacotroy17 and crashnburn80 like this.
  13. Jul 20, 2023 at 6:46 PM
    my.taco
    The brighter and whiter LED's are NICER on my eyes.
    BTW, no need to jump down my throat.
  14. Jul 20, 2023 at 6:51 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    I apologize if you've taken it that way, but the OP of that thread has done EXTENSIVE testing on headlight bulbs. Tons of foreground light tells your brain that your headlights are better, but distance throw (what actually matters) points a much different story.
    https://www.tacomaworld.com/threads...11-projector-headlights.589465/#post-19689309
    Start at this post in the thread and look at the 18' and 42' lux values. Most LED bulbs can't match the OEM halogen, let alone the $20 H9 halogen mod.
  15. Jul 20, 2023 at 6:53 PM
    my.taco
    It's all good, i am reading the thread right now. :)
  16. Jul 20, 2023 at 7:22 PM
    sauhcee
    sauhcee [OP] Member
    how’s the condensation on the headlights if you have owned it for awhile ?
  17. Jul 20, 2023 at 7:25 PM
    USPfan
    Haven’t noticed any to date. It’s parked outside around the clock. They’ve only been installed for a couple months, I’ll let you know if I start seeing condensation.
  18. Jul 20, 2023 at 7:30 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    People like to point to that thread like it is their bible. And like the Bible, they choose to pick out the parts they like, and disregard the parts they don’t. See post #3894 and #1579 on that thread. The Morimoto and the Hikari are good performing drop in LEDs.
  19. Jul 20, 2023 at 7:39 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    The Diode Dynamics ain't too bad either. Been using them almost 4 trouble free years.
    fellow_expert likes this.
  20. Jul 20, 2023 at 7:52 PM
    Tacoma_SR5Pro
    Tacoma_SR5Pro Well-Known Member
    '16 SR5 Pro
    The only thing I would remember to do, is to install the fuse in the INJ slot and not the EFI slot.
    Morimotos manual says EFI but that's incorrect; otherwise your headlights will turn on randomly.
