Do I need hub rings or caps for these wheels?
Discussion in '1st Gen. Tacomas (1995-2004)' started by HCFab, Jan 11, 2018.
  1. Nov 4, 2019 at 7:31 AM
    04taccoo
    04taccoo Well-Known Member
    Cyrus
    San Diego
    2004 Tacoma prerunner 4x4 double cab
    4x4 conversion
    What size rings did you use?
  2. Nov 4, 2019 at 8:20 AM
    smw62891
    smw62891 Well-Known Member
    Stephen
    Santa Fe, NM
    09 Tacoma DCSB
    not sure if I understand what your asking. You want to go from whatever your current wheel hub bore size is to your toyota hub bore size which is 106.1 I believe.
  3. Nov 4, 2019 at 8:54 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    ThunderOne and smw62891 like this.
  4. Nov 4, 2019 at 11:47 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I'm wondering if I need these for my pro comp 8069s... I've always had issues with them sort of being vibrate-y ever since I've gotten them. If I stay the same speed the vibes go away but if I slow down/ speed up a small vibe comes back. Even if I install the wheel properly.
  5. Nov 4, 2019 at 12:35 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I guess wouldn't hurt to try, even a fraction of a mm off at the rotation tires spin will cause vibes
  6. Nov 4, 2019 at 3:38 PM
    HCFab
    HCFab [OP] Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    I've given up at this point, this thread WAS 2 years old... But I don't even care about vibrations anymore, just wheel harder.
  7. Nov 4, 2019 at 4:17 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    That's how I've been.. for the last 10 years lol
    HCFab[QUOTED][OP] likes this.
  8. Nov 11, 2019 at 8:25 AM
    therealmojoe
    therealmojoe Member
    Joe
    Los angeles
    2014 tundra
    6" coilover lift
    All procomp wheels are lug centric and require a splined lug nut with a 60 degree conical seat taper. Not to mention you cannot run hub centric rings on Procomp steel wheels. Try using the correct lug nuts first, then see if you still experience vibration.
  9. Nov 11, 2019 at 8:42 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    this is what I use
    https://www.summitracing.com/parts/gor-41138et/
    also my wheels are alloy, not steel
