Do I NEED more power? Does my family need to go on a diet?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MasterYogurt, Jun 18, 2018.
  1. Jun 18, 2018 at 10:45 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    For what you’re doing, keep the RPMs near the torque peak.
  2. Jun 18, 2018 at 10:48 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    If you want a better response and less gear shifting then regear with 4.88’s. These trucks are geared super high with double overdrive to meet fuel standards. You’ll see minimal fuel efficiency hit but your trans will stop wondering as much and it will have more getup. The engine can make good power, but you’ll never feel it with ratios that come with it at the factory. It needs to see RPM to move.
  3. Jun 18, 2018 at 11:11 PM
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    Set cruise, turn music up and enjoy the trip.
    Take a look at shift sense pro. It holds gears longer and keeps you in the power bad for about $150.
  4. Jun 18, 2018 at 11:25 PM
    MasterYogurt
    MasterYogurt [OP] FNG
    Kevin
    Florida
    2018 Taco TRD Off Road 4x4
    My foot.
    Ok that was a good read until it gave me VANOS flashbacks and I wanted to throw up and burn my wallet lol.
    Maybe if I lift the truck I'll consider a regear.
    No easy suggestions for more power then, huh?
  5. Jun 18, 2018 at 11:26 PM
    Jukeboxx13
    California
    Take a hard look at shift sense pro. Doesnt add power but really improves driving experience.
  6. Jun 18, 2018 at 11:30 PM
    whoareyou133
    whoareyou133 Well-Known Member
    Claremont Los Angeles
    02 Prerunner TRD
    No pre runner trim, no mud flaps,no step ups,I do have the Deck plate though. Kings @ 0 and 5100's in rear. stock leafs. Total chaos UCA.
    65 slow lane 2000 rpms or under all most of the time. taco life. you learn to love the feel of the road at slow speeds.
    bobrown14, bv8ma and boynoyce like this.
  7. Jun 18, 2018 at 11:39 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I’m guessing her civic will take you off the line....
    Just about everything gets me
    Suggestion for more power: Get a new F150
  8. Jun 19, 2018 at 12:49 AM
    rowsdower
    rowsdower Well-Known Member
    With a completely empty truck (except me), mine will hunt between 3rd and 6th while maintaining 85 with cruise control. It seems to hunt less with cruise control off. Mine is a 2018 TRD OR 2wd with ShiftSense Pro. The drivetrain just sucks for high speed driving. Anything below 70 and it is a LOT better. Learn the behavior of the S modes. There are 6, and the one that you choose is the upper limit. So if you are in S5, the truck will shift normally between 1-5th but will not go to 6th. S4 will limit the truck to 1-4th but will not shift to 5th or 6th. S6 is basically the same as D.
    In my opinion the ShiftSense Pro is not really worth it. While not quite as much as stock, mine still gear hunts and pisses me off daily during my commute (25 miles each way @85mph). All the SSP does is read the truck's speed and throttle input from the OBD port and automatically shift between S2-S6. If SSP has you in S5, you are still at truck's mercy when it decides it needs to be in 3rd gear to go from 83mph to 85mph. Yeah, I really needed redline for that, Taco :facepalm:. Around town, SSP does make it a lot better but it still doesn't do what I want it to do. Recently I've been just putting it in S5 manually when I get on the freeway and dropping to S4 before the bigger hills. This keeps me out of 3rd at least.
    I have not driven an OVTuned truck, but I hear good things. I also heard good things about SSP though, so... :notsure:
    bensonxj likes this.
  9. Jun 19, 2018 at 2:45 AM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    Ect might keep it out of 6th but if you put it in S5 it will definitely keep it out of 6th. As someone said earlier, 5th and 6th are both overdrives in this truck.
  10. Jun 19, 2018 at 3:18 AM
    GR8APE
    GR8APE Well-Known Member
    Buy it ...then try it?
    Topanga Taco likes this.
  11. Jun 19, 2018 at 3:49 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Anything else to add?
    You realize that once something like OVtune is on your truck... it doesn't "expire". LOL, gimme a "trial" version for free. I'll take it off if I decide not to purchase.. HONEST.
    Maybe Mat should organize a travelling road show for you.
    :rolleyes:
  12. Jun 19, 2018 at 3:51 AM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Intersting... When we go camping it's a family of 4 in the truck about two hundred pounds of stuff in the bed (which includes two coolers full of ice a tent and a canopy) plus all the other camping gear. I also have a four bike rack with four bikes on the back. Doing 75 it's usually at around 2500 rpms and if I have to go up a hill, incline or something it jumps to 3000 for a bit and then back down to 2500 again.
  13. Jun 19, 2018 at 4:02 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    That same drive back in January from Big Bend State Park to Houston is why I got the OVTune and love it! My friends convoying were yiping the whole time asking why I couldn't cruise at 75-80 mph. Unfortunately there was 6-8 mph head winds and it just jumped from 4th-5th every 10 secs for 11 hours. Installed the OVTune and it will hold 5th longer and actually drive in 6th. To do 80+ mph its in 5th no matter what but I have a few mods (3" lift, 33" tires, 400 lbs of armor, 400 lbs of gear). I run the 91 octane with 93 now and I hardly ever hit 4th unless I'm accelerating or there is more than 4-5 mph winds which is quite a bit on the coast when I drive from Lake Charles to Houston every week.
  14. Jun 19, 2018 at 4:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yes.
    Or overgeared.
    Depending on who you ask.
    Changing 2 sets of final drive gears is not a cheap solution. Compare that cost to MPG lost by running in 5th on loaded hwy cruises, and I'll bet you find the ROI will be about 4 years after you've sold the truck.
  15. Jun 19, 2018 at 6:20 AM
    #35
    GR8APE
    I'm well aware that you can't test drive everything you buy in life but something as expensive as a new truck shouldn't be one of those things. I also know that you're not going to be able to test drive in every situation you'll likely encounter later on . There's just too much information on Tacoma World to not know that others are complaining about their Tacomas not pulling like a DuraMax or at least test driving more than just around the block ,Oh and I don't test drive my underwear before I buy it either, and then again I don't get on some forum and complain about them not fitting right. If you keep reading on this forum you'll see a lot of buy before you try.
    MOC221_[QUOTED] likes this.
  16. Jun 19, 2018 at 6:31 AM
    #36
    coppil
    coppil Well-Known Member
    '18 Cement TRD OR 4x4
    Did you note what kind of MPG you were getting before and after the OVTune and going 80+?
  17. Jun 19, 2018 at 6:44 AM
    #37
    DrVonEvilSatan
    Toyota Truck
    Nope, no easy performance upgrades. But you really don’t need more power. I just went camping last weekend with the in-laws. Towed their tent trailer loaded with their camping gear at 1500lb, all of them, my wife, my dog, myself for about 750lb. My truck had a soft topper, RTT, fridge, cooler, all of my other camping gear for another 300-400 lb. I had 0 problems pulling 6% I-5 grades for a couple thousand feet worth of elevation in NorCal and Oregon and keeping with traffic up at 70mph. But I have a 6 speed with lower OD’s in 5th and 6th and a final of 4.30 and can keep the RPM where the engine likes to live life. If you have an auto 4.88’s are really the only thing this truck needs to feel more preppy, and even then with them you’re still geared slightly higher than an MT.
  18. Jun 19, 2018 at 6:54 AM
    #38
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    Max Payload is only about 1000-1150 lbs on these trucks. My door Jamb says max is 1000 lbs and that has to include any passengers and cargo. As others pointed out the issue is gearing and the fact that 80 mph is pretty quick for something that looks like a brick. Your fuel econ will drop dramatically as well going from 60 to 70 and even more so when you go from 70 - 80 mph
  19. Jun 19, 2018 at 7:06 AM
    #39
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    So we are complaining about 85 mph + with cruise now ? :facepalm:
  20. Jun 19, 2018 at 7:08 AM
    #40
    TacoRD16
    Houston, TX
    Guess that would help! lol
    Before OVTune (Trip): 14 mpg @ 75 mph
    Before OVTune (Normal): 16-17mpg @ 75 mph
    After OVTune 87 tune : 18 mpg @ 75 mph
    After OVTune 91 tune: 19 mpg @ 75 mph
    bobrown14 likes this.
