Do I need new center pins for 1.5" block?
Discussion in 'Suspension' started by pivey14, Jun 19, 2013.
  1. Jun 19, 2013 at 7:07 PM
    pivey14
    pivey14 [OP] I'm A Grinder
    Patrick
    Baton Rouge, LA
    '11 DC Base PreRunner
    See Build Thread
  2. Jun 20, 2013 at 4:26 PM
    rfsdave
    rfsdave Member
    Dave
    Mass
    '13 TRD Off Road
    5100's all around, fronts @.85, Wheelers 3 leaf progressive AAL with the shortest leaf removed & no overload. (1.0" lift)
    no, but you will need new u-bolts
  3. Jun 20, 2013 at 11:19 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You'll need centerpins & Ubolts....
  4. Jun 20, 2013 at 11:33 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Centerpins, why?
  5. Jun 20, 2013 at 11:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Because the stock ones are cut off short to clear bump stops for one & 2: adding a 1.5" block is going to leave the pin about an inch short & lastly you should always replace centerpins if removing (but not a deal killer if you don't)
  6. Jun 20, 2013 at 11:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Also you can easily make your own, just get a 3/8" fine thread grade 5
    (or better) bolt, about 4"-5" long with a nylock to match, just grind the corners off the head of the bolt & it fits perfectly into spring perch on axle
  7. Jun 21, 2013 at 6:46 AM
    rfsdave
    rfsdave Member
    Dave
    Mass
    '13 TRD Off Road
    Help me out here. Why would you even touch the center pins if all you are doing is adding a lift block? The block goes between the spring and the axel, so there is no need to take apart the spring. I can see it if your doing a add a leaf. What am I missing here?
  8. Jun 21, 2013 at 6:53 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What lift blocks do you have?
    I know its been many many years since I've helped someone install lift blocks - but we never messed with the centering pins. The lift block sits on top the head of the pin (hole in block) and has a nub on the other side that sits in the spring plate. Longer Ubolts ...YES. But you never had to touch the centering pins.
  9. Jun 21, 2013 at 6:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^^
  10. Jun 23, 2013 at 12:19 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    My bad confused block with leafs..... HEY I'm old Goddammit !! Its a senior moment (or is it movement ??):p:eek::eek:
    its a Ubolt thing.....nevermind.....:eek::eek:
