Do I need new shocks.
Discussion in 'New Members' started by loonskier13, Feb 6, 2014.
  1. Feb 6, 2014 at 10:16 AM
    loonskier13
    loonskier13 [OP] Member
    2002 reg cab 4wd 5 spd taco.
    3 inch tuff country suspension lift. 31 inch tires.
    I wanna get the bilistein 5100 shocks. It says they lift the front end of my truck 2.5 inches. If I get these will I need bigger coil springs
  2. Feb 6, 2014 at 10:18 AM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    No. These work with your stock coils. You can adjust the spring perch which will compress the spring which gives your truck up to 2.5" of lift. There are three settings. 0" of lift, 1.25 or so I believe and then 2.5" of lift. I have mine on 2.5" setting and it rides great.
    You will need to lift the rear though as well... 5100's do not lift the rear. You will need an Add a Leaf or block or shackle or whole new leaf pack. I have a 2" AAL in the rear and am very happy with it.
  3. Feb 6, 2014 at 11:18 AM
    SaltSlasher
    SaltSlasher Member
    Utah
    04' Tacoma Reg. Cab 4x4
    Factory Upgrade Package's: -Alloy Split Star 5 Spoke -P265/70R16 Tires -Overfender -Hood Protector Add On's: -Black License Plate Cover -Heavy Duty Floor Mats
    From what I read, the stock Tacoma, is 1" higher in the back. So people will get leveling kits, and lift the front end up 1" to get an even look.
    So when I buy a set of 4 Blisteins, I am going to adjust them to see which settings I like the most. I have read tons of places that people just don't want their truck lifted, which I get, I just know they look much better when they are lifted, at least that is my personal opinion.
    I am also looking at the Coil Overs/Leafs aka Full Suspension upgrade, mostly on account that can be enough for my general use, and not breaking the bank. Later I will look into a SAS upgrade, steering upgrade, and etc.
  4. Feb 7, 2014 at 3:29 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Welcome to TW :wave:
