Do I Need New Springs…
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AntMan408, Apr 15, 2022.
  1. Apr 15, 2022 at 6:21 AM
    AntMan408
    AntMan408 [OP] Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    I will be adding a steel bumper, winch and lightbar to the front. Below I have listed what I have or will have on the vehicle. I currently have 600LB springs on the front they are kings. I would like to maintain current stiffness and height. Would I need to go to a 650LB spring or 700LB spring? Can anyone chime in, any input would be greatly appreciated. Thank you.
    Bumper:108LBS
    Winch:68LBS
    Lightbar:10LBS
    Rci Sliders:98LBS
    RCI Ifs, trans and diff skid aluminum:68LBS
    Total Weight:352LBS
    Total Weight Up Front:195ish LBS.
  2. Apr 15, 2022 at 6:33 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    You’ve added over 200lbs up front or 100+ pounds per corner. Given the same dimensions 700lb coils.
    Mark77 and AntMan408[OP] like this.
  3. Apr 15, 2022 at 6:39 AM
    AntMan408
    Bay Area, CA
    I’m not sure how spring rates work and how you calculate spring rate need based off weight. could you break it down for me, sorry I just want to educate myself on this.
  4. Apr 15, 2022 at 6:47 AM
    JoeCOVA
    Joe
    Colorado Springs
    The super short answer is that a 600 pound spring takes 600 to compress 1 inch, 1200 for 2 etc. Adding weight causes the springs to compress more. People offset the changes in ride height from compression either with more preload or swapping springs.
    Road_Warrior, eurowner and drizzoh like this.
  5. Apr 15, 2022 at 6:53 AM
    AntMan408
    Bay Area, CA
    thank you for the information.
  6. Apr 15, 2022 at 6:58 AM
    JoeCOVA
    Joe
    Colorado Springs
    I think you can get away with either spring rate 650/700. Just hard to calculate without corner weights. A lot of people only count what’s up front but forget that the sliders and skids add some as well based on weight distribution.
    In the early part of my build I went with 700 and was very happy
  7. Apr 15, 2022 at 7:00 AM
    AntMan408
    Bay Area, CA
    is the 700 super stiff? I want to maintain what I currently have and I don’t want to do anymore preload to maintain the height I have.
    Bee Finn likes this.
  8. Apr 15, 2022 at 7:37 AM
    Ez2typethis
    Ez2typethis Well-Known Member
    California
    2017 Sport
    Suspension -LSK Uniball Uper Control Arms -LSK Uniball Lower Control Arms -Camburg Performance Spindles -ECGS Needle Bearing Installed -Archive Garage Hammer Hangers -Archive Garage 3.6” Shackles -Archive Garage Hanger Cross Tube -Icon 2.5 CDC Extended Travel Coilovers -Icon 14" 700 pound coils -Icon 2.5 CDC RXT Shocks -Icon 2.0 Hydraulic Bump Stops *Bolt On Bump Stop Mount -Wheelers Front Super Bumps Armor -At The Helm Front Bumper -At The Helm Rear Bumper -At The Helm Rear Swing Out -RCI Sliders -RCI Engine Skid Plate -RCI Transfer Case Skid Plate -RCI Transmission Skid Plate -RCI Fuel Tank Skid Plate -Prinsu Designs Top Rack -Prinsu Designs Cab Rack Lights -Black Head Light Mod -OEM TRD Pro Tail Lights -MESO LED Turn Signals -Morimoto HID Headlight Kit -Caliraised LED 40” Slimline -Caliraised LED 20” Slimline -Caliraised LED Amber Pods -Caliraised LED Wide Ditch Lights -Caliraised LED Flush Mount Pods -LED High Beams -LED Dome Lights -LED Back-Up Lights -LED License Plate Lights Miscellaneous -OVtuned2.0 -4.88 gears -ARB twin comp -ARB rear locker -Leer 100XQ Camper Shell -Smitty Built X20 Winch -Warn Fairlead -Warn Sidewinder -Roto Pax 4.5 Gallon Gasoline -Roto Pax 2 Gallon Water -Roto Pax 2 Gallon Gasoline -Weathertech Floor Liners -Double limo tinted -50% tinted windshield -Leather Seats - Installed At Dealer Wheels and Tires -Matte Black Stealth Custom Series Ray 10's (X5) -BFG KO2 285x70r17 // Load Range C (X5)
    I had 650's on my icons but switched to 700's because the 650's settled A LOT. I would make adjustments only to have it settle down to the original ride height a few weeks later.
    Noticed a very very slight increase in stiffness when switching to 700's but barely. Drove a 3/4 diesel Silverado before and its butter compared to that thing.
    My truck is pretty heavy weighing in at 5900 pounds with just me and fuel in it.
    I vote 700's
    AntMan408[OP] likes this.
  9. Apr 15, 2022 at 7:59 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    A 600 lb/in spring will compress 1" for every 600 pounds. Because the spring is connected at about the halfway point of the lower control arm, there is a 2-1 "motion ratio" and thus each 1 pound you add to the truck is effectively 2 pounds. Additionally, because of the 2-1 motion ratio, the for every 1" the spring is compressed the wheel moves 2".
    Therefore given some added weight, the height will change thusly:
    height = weight * 4 / 600
    Example:
    height = 100 lb * 4 / 600 lb/in = 0.66 in
    I suggest attempting to get the 0.66" back by increasing preload. If you max out preload and still cannot get to your desired ride height, then replace your springs with 650 or 700 lb/in ones.
    AntMan408[OP] and Bee Finn like this.
  10. Apr 15, 2022 at 8:03 AM
    Bee Finn
    Bee Finn Well-Known Member
    Brandon
    St. Louis, MO
    2021 White Tacoma TRD Off-Road
    yeah play with preload first. Otherwise i'd say go with 650lb.
  11. Apr 15, 2022 at 8:05 AM
    AntMan408
    Bay Area, CA
    Thank you for the detailed breakdown.
  12. Apr 15, 2022 at 8:07 AM
    gudujarlson
    Minnesota
  13. Apr 15, 2022 at 8:15 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yup agreed. Preload doesn't hurt ride quality unless you are coil binding or you have no droop. My trucks 5700lbs, and Im still rocking the stock 13'' 600lb springs and they are great. Im only sitting maybe 1.75"-2" over stock, so anymore preload would be coil bind and to get more height if I wanted for some reason I would just go to a 14'' 600. Could see someone going to a 650lb for the height they want, otherwise I see no need for a 700lb spring.
  14. Apr 15, 2022 at 8:25 AM
    Bee Finn
    Brandon
    St. Louis, MO
    ^ yup. Im full steel skids, sliders, no bumper or winch but on icon 13" 650lb springs and they're too stiff for weight transfer when articulating. Going to go to a King or Eibach 14" 600lb spring to soften up the front.
    AntMan408[OP] and Buttskevin21 like this.
  15. Apr 15, 2022 at 8:29 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Yeah that's one thing that's a huge downfall of 650/700lb springs. Under flex, the front end will hardly do anything if the weight transfer is to the rear. For example driving up onto an ecology block, my front still fully compresses. 650 or 700 the front wouldn't see the same compression.
  16. Apr 15, 2022 at 8:41 AM
    Bee Finn
    Brandon
    St. Louis, MO
    Boom. Its nice to see others understand the differences in springs and preload and what they affect. Theres sooooo much misinfo out there about it. Took me awhile to understand what was correct.
    Ideally we want to run the softest springs we can until it causes sag issues due to weight.
  17. Apr 15, 2022 at 9:20 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    I agree try more preload before going with heavier springs. I have more weight then you have listed OP and am on Dobinsons 580lb springs. I'm also at the max preload for the lift I want. They've been holding the weight, ride great, and articulate easily.
  18. Apr 15, 2022 at 11:57 AM
    JoeCOVA
    Joe
    Colorado Springs
    Why?
    Preload should be used to adjust ride height, not compensate for poor rate selection.
    When building custom suspensions you start with the corner weight, not whats the lowest spring rate I can run without binding
    nhpoke likes this.
  19. Apr 15, 2022 at 2:40 PM
    gudujarlson
    Minnesota
    I’m not following you. Can you elaborate?
  20. Apr 15, 2022 at 3:37 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Just to throw in my .02 since I was in the same boat with much more weight - I was sure I needed 650 or 700lb springs.
    Reached out to Accutune to see what they suggested. My rig: fully armored w/ 33" tires, front & rear bumpers, winch, Diamondback, roof rack, etc: additional weight - Front - 375 Rear - 500. This was actually before the RCI full steel skid package & roof rack. Mix of 70% onroad, 30% offroad driving. Mostly high speed desert runs and overlanding, not much technical rock crawling. Crunched the TRD pro front aluminum skid so aggressive at times and encounter many rocks. Hence the decision to go all steel.
    Here was the recommendation from Accutune: 05+ Tacoma Mid Travel Suspension Kit, Stage 4A – Fox
    2.5 inch lift
    14" 600# Spring
    RXT Option 3 with additional leaf.
    Adventure Tune
    DSCs will be set at softest setting and can adjust hi/low speed compression.
    They were spot on with their suggestion, but I do have to adjust the DSC dials when encountering whoops and such. Just one more thing to do when airing down. Also have to keep track of different settings for different terrain. Bit of a pain in the ass, but the increased performance is worth it. Then you have to remember to dial it back when you're done playing. I have a buddy that has the Pro suspension on his OR and with C rated tires, doesn't air down. He's always waiting on me whenever we hit trails. Something to be said for simplicity.
    This is how she sits
    Lastly I say 'high speed desert runs'. Very subjective. My rig is still a heavyweight pig and even with top of the line suspension, you'll still feel it. If you really want a capable high speed desert vehicle, buy a Razr.
