Do i need new U-Bolts?
Discussion in 'Suspension' started by WheelinJ91, Oct 30, 2012.
  1. Oct 30, 2012 at 9:35 AM
    WheelinJ91
    WheelinJ91 [OP] Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    So I will be installing my OME lift from Toytec with 1.5 AAL in the rear and was wondering if when i install the AAL will i need new ubolts or will the stock ones work?
  2. Oct 30, 2012 at 9:38 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Stock ones will work just fine. I used stock for my 2" AAL's.
  3. Oct 30, 2012 at 9:39 AM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    Alright awesome, i just noticed that some Toytec kits came with new u-bolts so i wanted to make sure before i started.
    Do you happen to know were i can find the torque specs for my suspension (Ubolts, Shocks bolts, ect) ?
  4. Oct 30, 2012 at 9:41 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I was worried the stock ones were to short but they arent and even the shop I got them installed at said they were good to go. I'm not to sure on the torque specs though?
  5. Oct 30, 2012 at 11:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  6. Oct 30, 2012 at 12:02 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Jan has a good point. ;) I've had my stock U-bolts on now since November of 2008 and I just check them every so often and so far they havent moved.
  7. Oct 30, 2012 at 12:15 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    What torque spec are you torquing them to? I keep tighting mine. Seems to me they are stretching. I'm going to 73#.
  8. Oct 30, 2012 at 12:17 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Not sure what the torque specs were cause a shop did it.
  9. Nov 4, 2012 at 8:34 PM
    WheelinJ91
    Edmonton,AB
    2012 TRD DCSB
    What size U-bolt will i need as i have decided to get new ones, I have the 1.5 AAL with the 4 leaf pack?
  10. Nov 5, 2012 at 7:48 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    To be honest with you I dont think you will need new U-bolts.
  11. Nov 5, 2012 at 10:16 AM
    BTO
    California
    Here's one way to be sure. Measure the thickness of the AAL (or find out how thick they are). Measure the amount of U-bolt sticking out past the nuts. If the thickness of the AAL is at least a 1/4 inch less then no need to replace the U-bolts.
  12. Nov 5, 2012 at 10:21 AM
    cgs2k2
    cgs2k2 old man
    this. its 20 dollars people. why spend all the money on the lift and cheap out on the least expensive object you could add
