Do i need new uca's???need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meckleystephen, Apr 20, 2010.
  1. Apr 20, 2010 at 5:33 PM
    meckleystephen
    meckleystephen [OP] My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    I searched and all i could find is a thread on pre-runners and was wondering if the 4WD were the same. i have blistein 5100's on order and was wondering if i also put a 1.5" aal in the rear with the front set at 2.5 will i need new uca's
  2. Apr 20, 2010 at 5:36 PM
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I think most here will say yes, you'll need the UCAs...others will say no but prolly wont be able to produce an alignment sheet withing specs. That's the way most of these threads go anyways....I personally don't know but I've read a ton of these type of threads.
  3. Apr 20, 2010 at 5:39 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    a good alignment guy can get it "within" specs...but it won't be optimal.
  4. Apr 20, 2010 at 5:40 PM
    meckleystephen
    Stephen
    York, PA
    yea so have I but it seems i always get more confused the more I read I know I should get them but I guess I will just level it out thanks for the input
  5. Apr 20, 2010 at 5:41 PM
    jmed99
    SC
  6. Apr 20, 2010 at 5:43 PM
    jmed99
    SC
    Anyone that says they can get an alignment within specs please post your alignment spec sheet. Thanks!
    (((I'm guessing this will now be a short thread)))
  7. Apr 20, 2010 at 5:57 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    There you go thinking again....always a smartass in the group.
    Keep in mind this is a 3in ProComp Lift and everything is in spec aside from my caster being off by 1/10th. Cross caster is fine.
    Edit:...Granted, the numbers are not pretty (the reason i am running LR UCA's), but they are in spec, this is from a toyota dealership.
    OP is asking about a 2.5 in lift so im sure his numbers wouldn't look near as bad, And i believe the tech could have gotten mine better but he was working on it longer than he wanted to be and was tired of messing with it (notice the time...right at quitting time).
  8. Apr 20, 2010 at 6:04 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    TC UCA helped more than i could believe. Worth every penny!!!!
  9. Apr 20, 2010 at 6:05 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    How much were they and where did ya get them?
  10. Apr 20, 2010 at 6:10 PM
    jmed99
    SC
    Your caster is off...exactly. So yours is not within the specs. Aftermarket UCAs will help you get the caster within spec. Sounds like UCAs are needed to get within all the specs.
  11. Apr 20, 2010 at 6:11 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    I have more lift than OP. And considering mine was only off by 1/10th, with a good tech his should be all within spec. The only way to find out is if he took it and tried to get it aligned to see if it is close enough for him. Personally the 1.2 camber is what killed me...not the caster. Camber really needs to be at 0 or -/+ .01.
    I run LR UCA's and my caster setting on the UCA's is set at 0.
  12. Apr 20, 2010 at 6:13 PM
    meckleystephen
    Stephen
    York, PA
    alright well how about if i went with a toytec aal 1.5" and set the front at 1.75????
  13. Apr 20, 2010 at 6:16 PM
    jmed99
    SC
    I read somewhere that below 2" in the front you do not need aftermarket UCAs. I can't remember where I saw that though.
  14. Apr 20, 2010 at 6:17 PM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    Yea I read some where that only above 3' you need UCA. It is starting to seem its one thing or its another.
  15. Apr 20, 2010 at 6:19 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2011 4x4 DCSB TRD Off-Road
    Leer 100XL and a bunch of off-roading scars.
    3'??? :p
  16. Apr 20, 2010 at 6:19 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Well i have 3in, and you see the specs....its not pretty. 2in lift and stock uca's should be good, 2.5...get a good alignment tech and check the specs...if you have the cash to spend i'd go ahead and get them to make life easier, but you could limp along on stocks to save up some cash, 3in...go ahead and get the UCA's, because if it is within specs...its really not gonna be close.
  17. Apr 20, 2010 at 6:24 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Im installing my 5100's this weekend also, if my 2" Toytec AAL's get here by Friday. I don't have the tsb springs, and I'm going to set the fronts to 1.75. From what Iv'e read we don't need UCA's
  18. Apr 20, 2010 at 6:25 PM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    So for Stephen he should be fine. Cause what he was going to do is what I was going to do this month. So I was wondering the same thing.
  19. Apr 20, 2010 at 6:26 PM
    Chief10Taco
    Chief10Taco Well-Known Member
    Rob
    Tampa, FL
    2010 TRD Off-Road 4X4
    weathertech floor liners, weathertech bug deflector and side window deflector, and wet okole front seats
    I have read extensively and it seems like the consensus is that they are not required with a small lift, but they do make the truck ride alot better. They help keep the "factory Feel" drive. LR UCA's are a good less expensive brand that get good review. TC UCA’s, which are better from what I have researched, just cost much more. Hope this helps.
  20. Apr 20, 2010 at 6:26 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    They do make a difference...that is for sure.
