Do I Need Remote Reservoirs?
Discussion in 'ICON Vehicle Dynamics' started by kwolf9202, Apr 12, 2019.
  1. Apr 12, 2019 at 11:22 AM
    kwolf9202
    kwolf9202 [OP] Well-Known Member
    Kris
    Morrison, CO
    2018 TRDOR DCSB
    Looking to lift my 2018 TRDOR DCSB and I am between the stage 3 and stage 4 kit. The truck is my daily driver and I go wheeling about twice a month. At what point would I need RR's?
    Icon_Adrian likes this.
  2. Apr 19, 2019 at 10:06 AM
    Icon_Adrian
    Icon_Adrian Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
    A shock absorbers main function is to convert kinetic energy to heat and then dissipate that heat into the atmosphere. Remote reservoir shocks have a larger oil capacity thus have the ability to absorb more energy. If you are not going to push the vehicle hard for extended periods of time, the IFP coilovers will provide plenty of performance over stock while not being overworked to the point of shock fade.
  3. Apr 19, 2019 at 10:36 AM
    kwolf9202
    Kris
    Morrison, CO
    2018 TRDOR DCSB
    Thanks for the reply. I ended up going with the stage 4. Better to have them and not need them than need them and not have them I guess!
    Tatts521 and Icon_Adrian[QUOTED] like this.
  4. Apr 19, 2019 at 10:40 AM
    Icon_Adrian
    Adrian
    Riverside CA
    "Better to have them and not need them than need them and not have them"
    :thumbsup::thumbsup::thumbsup:
  5. Nov 20, 2019 at 7:26 AM
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    I'm on the fence too...between the Stage 3 and Stage 4. Correct me if I am wrong, Stage 3 comes with RRs ONLY on the rear shocks, correct? Stage 4 is RRs all around, right?
    Pretty much same driving situation as @kwolf9202 as well, daily driver with some frequent wheeling but on a 2017 TRDOR DCSB.
    Later.
  6. Nov 20, 2019 at 7:31 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Unless you plan to run the dessert for 10+ hours in a day, the RR's probably wont come into play. I think 2.5s will be good enough for what your planning. However if you have the coin, and you like having the option (+ compression adjustment capability), go for what you want and dont let anyone tell you that youre making a bad decision.
    Icon_Adrian and imjustabill1970 like this.
