Do I need the compressor belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gen1TacoBen, Jan 21, 2025.
  1. Jan 21, 2025 at 3:38 PM
    Gen1TacoBen
    Gen1TacoBen [OP] New Member
    2001 white Tacoma 4x4 TRD
    When I bought my 2001 Tacoma the serpentine belt that runs to the compressor was missing, but it’s been driving just fine (with no AC of course). Recently in the cold weather my other serpentine belts have started squealing for a few seconds on a cold start and the power steering belt is starting to fray on the sides just a bit. I was going to replace the belts going to the power steering and alternator for now, but should I even worry about the compressor belt? The idler pulley for the compressor is seized so I’d have to replace that too. Just trying to get by replacing as little as possible until summer when I commit to replacing the timing belt, water pump, etc, and I’ll do the compressor and idler pulley then. Mainly because it’s too cold to work outside right now for very long, and I don’t I don’t have a garage.
  2. Jan 21, 2025 at 3:46 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Nah
    Missing belt not squealing
    RR ac belt when the warmer arrives (and you start all that other work)
  3. Jan 21, 2025 at 4:00 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If your defrost isn’t working as well as it should you may want it, otherwise it’s fine to leave off.
  4. Jan 21, 2025 at 4:05 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    They removed the belt cuz the ac belt tensioner is seized as you stated most likely so they can continue to drive it.
    My buddy had one & the ac compressor was actually taking a dump, no idea if it was just the clutch field & pulley or internal compressor failure.
    Did the same thing, removed the belt so he can keep on trucking...
  5. Jan 21, 2025 at 4:18 PM
    Gen1TacoBen
    I guess my other question is- could the lack of the third belt possibly be causing the squealing? Since all three belts wrap around the water pump, my thought is that maybe the water pump doesn’t have enough friction on the cold start and causes the other belts to slip? Just spit ballin lol
  6. Jan 21, 2025 at 4:25 PM
    slater
    San Diego
    doubtful,
    most likely loose belt
