Do I need the TSB?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrdbrn, Mar 23, 2011.
  1. Mar 23, 2011 at 6:36 AM
    jrdbrn
    jrdbrn [OP] Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    I went to Lowes last night and bought an assortment of pavers. The majority were 6"x9" and some where 6"x6". 90 in total. I think it was like 60/30.
    I didn't realize until I got to my parents house that the truck was LOADED. I felt like I may have bottomed out once on our great Louisiana highways.
    I am assuming it was about 400 pounds. I didn't have a scale to weigh the stones.
    Here is what I was looking at.
    Is this normal or am I pushing the weight of the bed? The picture blows :-\
  2. Mar 23, 2011 at 6:46 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Good idea to get the TSB if you do alot of hauling. Sounds like you need it if it bottomed out with 400lbs.
  3. Mar 23, 2011 at 7:38 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    small pavers are about 4.5lbs each - 135lbs
    The larger ones are about 6.7lbs each - 402lbs
    So probably about 525lbs or so.
    These are the thinner, 45mm thick ones
    The thicker ones would be about 700lbs.
    - I just bought a pallet of the smaller ones, looked up weight for the trailer -
    As this is being discussed in other threads, if you rarely haul, and want a more "car-like" ride, keep the factory springs and deal with the occasional issue.
    If you regularly haul stuff in the bed, and dont mind a "truck ride", then look into getting it done.
  4. Mar 23, 2011 at 8:09 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Sounds like you need it to me. Do it and you won't regret it.
  5. Mar 23, 2011 at 8:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you still under warrantee? If yes....then GET IT.
    You paid a lot of money for that truck and deserve a better leaf pak to support hauling what the truck is supposed to haul.
  6. Mar 23, 2011 at 8:18 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Short answer : yes
  7. Mar 23, 2011 at 8:19 AM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    I would say if you like the ride of the truck normally don't get it done. It will lift the back a bit and you will have a raked unlevelled truck without a load forcing you to buy new shocks for the front to level it out and then the ride will be stiffer unless you are carrying a load..... I would put that money towards an Airbag system instead.
    Sounds as if you, like me, as a home owner only do that kind of heavier hauling a few times a year. Look into those Firestone adjustable airbags.
    When you load the truck pump em up. When you unload, release the air and get your carlike ride back. IF you want a semi free lift go for the TSB and find a place to install the front shocks.
    If the ride is only harsh when you are loaded I would not worry about it unless you are always loaded.
  8. Mar 23, 2011 at 8:23 AM
    OZ-T
    Peter North
    British Columbia
    I wonder why all of the Canadians don't complain about this un-level , harsh ride ?
    The answer is still yes .
  9. Mar 23, 2011 at 8:26 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    I would get it done. You won't notice a big difference in ride without weight in back, but much better when loaded down.
  10. Mar 23, 2011 at 8:39 AM
    Kingfrog
    Hard asses..? Canadians are not whiners and poseurs like Americans either. They likely actually use a truck for its purposes....at least Toyota thinks so.
  11. Mar 23, 2011 at 10:00 AM
    jrdbrn
    Jared
    Louisiana
    I'll contact the dealership I got it from. I do mow grass on weekends and when I load the mower to the front of the trailer, it does drop a BIT.
  12. Mar 23, 2011 at 10:00 AM
    Kingfrog
    I think a lot of us Americans would be too afraid to put a little scratch in the plastic bed...to carry a heavy payload of bricks. I would bet more Americans "Armor All" their Tacoma truck beds than Canadians...
  13. Mar 24, 2011 at 8:13 PM
    zuckdan
    zuckdan Well-Known Member
    Evergreen CO
    2011 DC SR5
    For sure get this done. I just did hours ago and couldn't be happier with the improved ride.
  14. May 20, 2011 at 5:50 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    Anyone know is the 2011 was part of the TSB? I dont carry much in the summer, but in the winter I like to add a few hundred lbs of bricks to my bed for added weight.
    BTW, anyone else add weight in the winter?
  15. May 24, 2011 at 8:47 AM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    2011 is included in the TSB
  16. May 24, 2011 at 9:34 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I didn't notice a harsher ride after upgrading mine- I suppose if your looking for it you'll feel it...
  17. May 24, 2011 at 9:38 AM
    puckstopper55
    Long Island
    I brought it to the dealer and they ordered the parts. Hopefully all goes well.
