Do I need the wiring Harness
Discussion in 'Lighting' started by cgmfl, Aug 13, 2012.
  1. Aug 13, 2012 at 8:11 PM
    cgmfl
    cgmfl [OP] New Member
    Orlando, FL
    '10 Prerunner TRD Sport
    Just bought a 2010 yota tonight and wondering if I need the wiring harness for DDM 55watt 10000k low beams. How about error eliminator? I had ddm in my 08 f250 and only had a few problems with lights not coming on immediately. Should I get 55 or 35?
    Thanks
  2. Aug 13, 2012 at 8:24 PM
    Davidd
    Davidd Well-Known Member
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    As long as you purchase the kit with the mounting harness you are good.
    Just know what your need. I have an 02 Tacoma but I know I needed an H4. Not sure what is needed in the newer Tacomas
    55 vs 35? It depends on what you are going to do with your rig. I have 35w on my headlights and they are plenty. I also have the hi low combo and when I go offroading, I have 3 35w converted into my hella 4000. I purchased 5000k in color.
  3. Aug 13, 2012 at 8:24 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I would just go with the 35 watt. 55 is way to bright, and if you're not doing a retrofit you will just be scattering light even more so. You don't need the error eliminator, that is for cars with a "burnt out bulb" detection system.
    I highly recommend spending a few more dollars and get the hi/low kit, it comes with the relay/wiring harness and everything you need to make it the HID's work without any modifications. I also recommend getting the analog ballasts, I have the digital ballasts in my fogs and they don't always light up when I turn on my lights, I have to flip the switch a second time to get them to work. I have the Hi/Low 6000k kit installed and it was super simple. There's a write up on here that covers everything you need to know to do the install.
  4. Aug 13, 2012 at 8:26 PM
    NelsonTacoma
    Tucson, AZ
  5. Aug 14, 2012 at 10:16 AM
    09DBLCAB09
    09DBLCAB09 Well-Known Member
