Do I need this stuff? U-Bolt flip kit, etc.
Discussion in 'Suspension' started by PreRunner, Feb 12, 2010.
  1. Feb 12, 2010 at 12:31 PM
    PreRunner
    PreRunner [OP] Well-Known Member
    got a 2010 prerunner single cab 4cyl, and ordered some suspension parts. ordered new icon coilovers custom valved, and camburg uca's for front. in back went with wheelers 10-leaf deaver pack and some 5100's. should i get a u-bolt flip kit as well? Do I need longer brake lines? anything else that i should consider? sorry if this is obvious im a bit of a newb. thanks. :eek:
  2. Feb 12, 2010 at 12:37 PM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    You dont need a U bolt flip kit. Thats all it does is gives you a little more ground clearance under your rear axel. And i cant wait to see the truck after all the goods are installed.
    But its not a bad idea. It will give you some extra ground clearance.
  3. Feb 12, 2010 at 12:41 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    you should probably get longer rear brake lines since your new leafs will allow for more travel and can/will put stress on the lines.
  4. Feb 12, 2010 at 12:43 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Longer brake lines only if your doing 3" lift rear
  5. Feb 12, 2010 at 12:48 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I would do the brake lines as a precautionary thing. Ive noticed even with my 5 leaf progressive pack, at full flex, there is alot of stress on my brake lines. I do have new ones in the garage waiting to go on though. Its better to have them and not need them that to not have them and tear one and be F**ked.
    I got mine from toytec for about 60 bucks
  6. Feb 12, 2010 at 2:35 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Also suggest axel shims (3 deg).
  7. Feb 12, 2010 at 2:40 PM
    PreRunner
    thanks. what are these for? where do i get them? difficult install?
  8. Feb 12, 2010 at 2:58 PM
    barlowrs
    Robert
    So Cal
    Toyotec makes them, they help eliminate axle wrap.
    http://www.trdparts4u.com/Scripts/prodView.asp?idproduct=-6713
    Also will need bushings for the rear, unless that leaf pack includes them, but most only include half of the bushings you need.
