Do I need this????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tsenekos, Sep 5, 2009.
  1. Sep 5, 2009 at 8:42 PM
    Tsenekos
    Tsenekos [OP] Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    hey guys I was telling someone about my new lift etc coming in the mail and he told me make sure you put in a beefier pitman arm????? is this necessary?? Im only running stock wheels with 265/75/16 3" toytec lift with coils and 5100's all around...what do you guys think is it needed?
  2. Sep 5, 2009 at 8:45 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Your friend is a genius, plus he saved you a headache by reminding you about that! Did he tell about your muffler bearing also:D. Our Tacos dont have pitman arms so no need to worry about that
  3. Sep 5, 2009 at 8:46 PM
    shockittillyareconizeit
    shockittillyareconizeit Well-Known Member
    Dustin
    California
    '07 Coma PreRunner
    Front - Icon 2.5 Coilovers, Maxtrac 4" lift spindles, TC UCA's Rear - Billy's 5100/1.5 AAL, 3" lift blocks MB Predator wheels - 16x8 plasti-dipped matte black Toyo Open Country A/T 305/70/16 Satoshi grille Blacked out badges DTRL Wet Okole seat covers
    Some bigger meats! :D And depending on what you set your coils at will determine what else is needed.
    If you plan on having it set at 2 or above, then getting new upper control arms would be a good idea. Otherwise, you don't actually NEED anything else.
    Then again, we all don't really NEED anything else, but we just can't resist. :D
  4. Sep 5, 2009 at 9:20 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    No they will be set at zero with the toytec coils to get 3" lift out of it, so I guess I'm fine with my order as is thanks
  5. Sep 5, 2009 at 9:27 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    while you install the beefed pittman arm be sure to check your blinker fluid. mine tends to run low sometimes... :D
  6. Sep 5, 2009 at 9:31 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    :sadviolin:jejejejejejejejejeje
