Do I need to a front diffdrop and sway bar relocate?
Discussion in 'ICON Vehicle Dynamics' started by REDdawn6, Jan 27, 2013.
  1. Jan 27, 2013 at 6:32 PM
    REDdawn6
    REDdawn6 [OP] Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Hey fellas. My friend is steering me to get an ICON setup up , coilovers , rear shocks and UCA`s . I have a 2011 Tacoma 4x4 Double Cab. If I went with the Icons, Do I need to get a front diffdrop? Do I need Sway bar relocate ? Anything else needed to run at 3' in front? Tks guys much appreciated ! RD6
  2. Jan 30, 2013 at 7:11 AM
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
    Do you "need" it 100%....I think that depends on actual front end lift height. Pushing the higher side 3"+ many will suggest it is a good idea to reduce CV angle. Swaybar brackets are not necessary for the 96 - 04 Tacoma's, those are required on the 05+ models. Make sure you do purchase the extended travel coilovers (uniball arms req) to take advantage of the addition droop travel they offer, and you may consider our progressive AAL pack or some type of lift should you want the rear level with the front when set to the 2-3" range. Otherwise you should be good....if you have any other questions let us know.
    Thanks!
  3. Feb 10, 2013 at 3:55 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    So at 3" I will I need a diff drop like lift systems?
    Thanks for the other answers!
