do i need to add a leaf???
Discussion in 'Suspension' started by tacosupreme54, Jul 31, 2010.
what to do?
Poll closed Aug 30, 2010.
  1. add a leaf and it will be fine
    16 vote(s)
    64.0%
  2. hell no, you need a new leaf pack
    9 vote(s)
    36.0%
  1. Jul 31, 2010 at 2:33 PM
    tacosupreme54
    tacosupreme54 [OP] Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    i have an 06 4x4 taco. i got the 2.5" front spacers a few weeks ago to level it up and fit 285's in the future, but it actually ended up making my truck a little nose high. so i planned on adding a leaf or block in the back to get it level sometime soon anyways. my thing is that i looked under the rear end the other day and noticed that my leafs look a little flat. i'm not sure if it's from sagging, the spacers in the front putting more stress on the back and flattening them out or what. i got my local tire and wheel guy to look at it yesterday to see what he thought. he said they looked somewhat flat but that he didn't know enough about toyota's to say if i needed to add a leaf or not. he said to look at some other toyota's leafs to compare. well i don't know anybody else with a toyota...but i do have you guys! haha, so what i'm wanting to know is do my leafs look flat to you or compared to your truck's leafs. i'm going to put something else under the rear soon as it is to level it up soon, so i would like to know if i would be fine just adding a block (i don't off road), adding a leaf to get more arch, or just getting a whole new leaf pack. i think i should just add a leaf because i need the lift clearance soon and it will fix the problem if there is one. please let me know if you have had this experience or just know, and what size leaf/block i should get, they are about the same price. i was thinking 1.5-2". any suggestions will be welcomed.
    i have heard that toyota's leafs just look flat as it is, and my mechanic also mentioned that my tonneau cover may be compressing them to make them look flatter. (it's an a.r.e. fiberglass tonneau cover, and actually i'd like to sell it if anybody is interested :D)
    thanks in advance
  2. Jul 31, 2010 at 2:37 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
    looks a little flat IMO but i dont own a second gen and have never got a good look at the leaves. id go AAL if it was me. theyre similarly priced to a block and would seem to solve youre problems if they do exist. plus ive never heard anything good about using blocks for lift and never anything bad about an AAL
  3. Jul 31, 2010 at 2:39 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    An add a leaf is a better option than a block, because blocks can promote axle wrap.
    Wheelers Offroad and Fat Bobs Garage make inexpensive AAL's that will get you the 1.5-2" you are looking for.
  4. Jul 31, 2010 at 2:45 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    i have seen that blocks are frowned upon and since they are the same price on toyotec as leaves, and offer better quality, i will probably get the leaves. however, do my leaves look flat enough to the point that i need a new pack? or do you think that it's just flatter from the weight of the tonneau cover? it's fiberglass. if it's just flatter from that weight, i will just get the leaf. but if they are wearing out, i want to get the whole new pack if i need to
  5. Jul 31, 2010 at 2:49 PM
    TexasTacoma37
    They don't look completely worn out, since they aren't resting on the overload spring. I bet the AAL would do the trick.
  6. Jul 31, 2010 at 2:51 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    AAL is the right way to go.
  7. Jul 31, 2010 at 8:07 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    yeah, they aren't "frowning" like a completely worn out set. i think the extra weight of the fiberglass tonneau cover might be one reason they are a little flatter, or it's at least a small factor in it. that thing has to weigh a good bit. what do you say? 1.5" or 2" aal? idc if the back is a little higher than the front
  8. Jul 31, 2010 at 8:09 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    yeah, that's what i'm leaning towards and figured was the right thing in the first place, but i just wanted to get some others' opinions. i'm thinking a 2'' aal. sound right? and btw, nice setup on your truck man, it looks good.
  9. Jul 31, 2010 at 8:11 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    anybody else have any input before i make a decision?!? i'm leaning towards the aal, but does anyone think it's necessary or better for my truck to get a whole new leaf pack? any/all advice or opinions will help
  10. Jul 31, 2010 at 8:21 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Well it's the same amount of work almost to install a new leaf pack. An add a leaf will firm up the rear end along with adding lift. A new leaf pack will give you a quality ride and lift. It's only a little more work to do a whole new leaf so IMO do a new leaf. I personally have an icon add a leaf :p
  11. Jul 31, 2010 at 8:29 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    ok, thanks. i just would hate to add a leaf and then here in a few years it gets wore out too and my whole pack is frowning. then i end up needing a whole new leaf pack. i guess that's the point i'm trying to make or question i'm trying to ask. i don't want to be doing a "fixer-upper" by adding a leaf instead of just solving my problem all at once by getting a new leaf pack. i don't know why they look flat. i don't off-road or do anything that would wear them out, so i don't get it. but then again all toyota leafs look somewhat flat and maybe i am just worrying about nothing; or like stated above, my heavy fiberglass tonneau cover might be making them look flatter.
  12. Jul 31, 2010 at 8:52 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    How much higher is the front right now? You might get away with a 1" aal but I'd go 2" if you don't mind a bit of a rake. You can handle a bigger load and should be good even if it saggs a bit over time or you decide to get a shell.
    I have a 2" AAL in the back with a SnugTop canopy. With a 2" spacer up front the truck sits 1" higher in the back.
  13. Jul 31, 2010 at 8:56 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    i don't know any exact measurements and it's not completely obvious or anything, but with it being my truck, i can tell. i'd say at least 1-1.5" higher in the front. i'm thinking 2'' aal because i don't mind the back being higher, it will be nice having it when towing, and i have a heavy fiberglass tonneau cover too. thanks
  14. Jul 31, 2010 at 9:17 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    IMO I would go new leaf pack, those look flat. Deaver or alcan or both good brands
  15. Jul 31, 2010 at 9:29 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Toyota 2nd gen leafs are known for sagging if you don't get the TSB. The add a leaf will be more than just a band aid to your issue. My add a leaf has worked wonderfully and not sagged a bit. You will be happy either way. The add a leaf is fine for your situation. It will definitely make the rear suspension stronger for load carrying. If you want a more plush ride than go three leaf add a leaf from wheelers. Since you are concerned about weight capability I would do the single two inch add a leaf.
  16. Jul 31, 2010 at 9:31 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    can anybody post up pics of their leaf packs? i would like to compare mine. also, is this possibly a tsb issue???
  17. Jul 31, 2010 at 9:35 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    yeah, i haven't had the tsb and i think it's too late for my 06'. plus i am the 2nd owner. but thanks man, that's the type of straight forward answer i was looking for.
  18. Jul 31, 2010 at 9:54 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    bump. anybody else got any help to offer?
  19. Jul 31, 2010 at 10:12 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    How much are you wanting to sell the cover for? :eek:
  20. Jul 31, 2010 at 10:16 PM
    OffroadToy
    For what it's worth the 2" AAL with the weight of the SnugTop canopy hasn't sagged much in the 3 years it's been on.
