Do I need to beef up suspension or not
Discussion in 'New Members' started by CluelessKId, Aug 2, 2021.
  1. Aug 2, 2021 at 8:17 PM
    CluelessKId
    CluelessKId [OP] New Member
    Maggie
    Tacoma 2017, 4 door, long bed TRD 4x4 Sport
    Bilstein shocks - Northstar 600ss camper
    I'm new to all of this. I bought an awesome 'new' 2017 Tacoma TRD 4x4 Sport last year and a (2009) Northstar 600SS just recently. EVERYONE says I NEED to enhance the suspension. Airbags sounded like more trouble then I wanted to take on (like the camper isn't). Then I learned of SumoSprings, sounded like a great alternative. I figured (being sadly clueless to all this) I'd go to experts in springs to do the work. Two local shops definitely do NOT advocate SumoSprings and advised adding a leaf. New concept to me. The more I learned/talk to folks the better that sounded. Then I talked to a friend who said NO WAY. He added a leaf to a Samuri and the ride was forever brutally rough. Is that an issue of smaller wheel base? Payload weight are pretty close to the camper - about 1500 (water on board); do I need additional? What is the wise, safe, lasting - easy for clueless - answer?
  2. Aug 2, 2021 at 8:21 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Don’t know but welcome to TW!
    skeletron and Black DOG Lila like this.
  3. Aug 2, 2021 at 8:23 PM
    Bishop84
    Bishop84 Well-Known Member
    Sumo springs are for occasional load, if you have heavy constant load air bags or leaf upgrades are the answer.
    You can always start with sumo springs and do an add-a-leaf later.
    Add-a-leafs ride rougher without load yes.
    Black DOG Lila and TnShooter like this.
  4. Aug 2, 2021 at 8:29 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    Sumo springs work all the time
    loaded or not they provide additional weight resistance...........the ride either way will be rougher
    adding a leaf has a similar result..............added weight capacity = the ride suffers
    some dont mind
    some get used to it
    some find its acceptable
    Air bags are adjustable if U dont have ‘ lift ‘
    Not interested in gaining undercarriage clearance
    the ride suffers the Least with the bags
    of the three the bags are the easiest to install
    maybe U can find someone with bags get a test ride
    Black DOG Lila likes this.
  5. Aug 2, 2021 at 8:33 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW…I went with Firestone Ride Rite air bags and like them a lot.
  6. Aug 2, 2021 at 8:45 PM
    Jose_Dirte
    Jose_Dirte Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    Hello Maggie,
    Welcome to TW.
    Samurai's have an extremely short wheelbase so at 79.9" so I do not doubt your friend experience a rough ride with add-a-leaf. Tacoma has a 127.4" wheelbase so your experience with an add-a-leaf would be alot better than your friend's.
    That said what do you plan to do with your truck?
    Just tow a trailer on gravel roads or take it on off road trails?
    Add-a-leaf should serve you just fine and are a low cost investment if you decide you would rather invest airbags later.
    If and when your stock leaf springs flatten out you can just replace them with a heavier leaf pack.
    If someone jumps on this post and says "NEVER do add-a-leafs!" ignore them, it's a weird TW snob thing that happens here.
    If your goal is to do moderate off roading we should be having a different conversation but I don't get the impression that is your goal.
    *Just realized that Northstar is not a trailer, lol. Invest in a new set of heavy leaf springs and airbags especially if you are going to always have that on.
  7. Aug 2, 2021 at 8:57 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Her profile implies DCLB so 140.6” wheelbase right?
    OP, you might want to give a bit more detail on this statement?
    “Payload weight are pretty close to the camper - about 1500 (water on board); do I need additional?”
    Does that mean your bed has 1500 lbs in it regularly or are you referring to the stock Tacoma payload rating? Are you carrying a tank of water for some reason? If you regularly transport something close to the max payload, I do think AAL or even a replacement leaf pack might be worth considering.
    More precisely, what exactly do you plan to do with your vehicle on a regular basis?
    Mine is mostly for hauling one child to something close by on a paved road so for me, unloaded ride quality is most important and the softish offroad suspension isn’t ideal, I’d be better with a more street oriented suspension.
  8. Aug 2, 2021 at 9:09 PM
    Jose_Dirte
    Joey
    Green Acres, CO
    I had missed it was a lb, but the biggest contributor in ride quality when comparing to samurai is the wheelbase and the length of the leaf springs themselves. Also if I remember my friends samurai correctly it had leaf springs at all 4 corners which I imagine would be extremely brutal with add-a-leafs combined with that short of a wheelbase.
    My Jeep TJ is miserable to drive anywhere that isn't off-road IMO and it has no leaf springs so I can't imagine how bad Maggie's friend's was to daily drive.
  9. Aug 2, 2021 at 9:16 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Timbren-Industries likes this.
  10. Aug 3, 2021 at 5:50 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Air bags for occasion heavy loads with towing.
  11. Aug 3, 2021 at 6:01 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    The OP's camper weighs 1,250 pounds dry, add in water and "stuff" and she has 1,500 pounds. I would definitely look at replacing the leaf packs with something designed to carry that weight constantly. Adding a leaf might help, but I would go full leaf pack. Air bags are better for occasional loads. A custom Deaver pack specific to your application is going to perform best.
    daveeasa likes this.
  12. Aug 3, 2021 at 6:05 AM
    su.b.rat
    su.b.rat broken truck
    sumos made the rear of my truck buck like a horse at highway speed. and i wore them out nearly to pieces using them. they are an effective yet crappy shortcut.
    welcome to the forum! @CluelessKId
  13. Aug 3, 2021 at 6:29 AM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    First things first, that Northstar is too heavy for a Tacoma! At ~1300 lbs dry, the camper plus your body weight and your truck is going to be over payload capacity (assuming 1440 lbs for DCLB), and that's without several hundred extra pounds of other people, water, food, gear, or beer.
    I mean, sure, you can put the camper in the back, beef up the suspension, and you'll get to where you're going, but you're going to be beating the shit out of your truck. You should definitely cut maintenance intervals (especially driveline fluids) in half and make sure to do consistent checks of driveline components. You'll also going to be a hazard to other drivers, especially at highway speeds or in inclement weather (make sure you have load E rated tires).
    I don't care what truck camper manufacturers claim or how their campers are marketed, mid-sized trucks are not intended to carry truck campers. What you need is a 1/2 ton truck, but probably not a Tundra since their payload capacity isn't much better than the Tacomas (although beefier axles, wheels, frame can probably carry more than door sticker indicates).
    For reference, my wife and I used to have a Northstar 850sc (dry weight of 1800 lbs). Us (350 lbs), a 60 lb dog, and four days worth of food, water, and hiking gear added 1100 lbs over the dry truck + camper weight. We were just under payload capacity in a Ford F250 (3050 lbs payload capacity), but would exceed it if we brought mountain bikes, bike rack, and that additional gear.
  14. Aug 3, 2021 at 6:33 AM
    JustJon
    JustJon Well-Known Member
    MI
    18 DCSB OR
    Sumo springs worked well for me, I pull a 2000lb camper with a bed full of bikes and family shit, no more 2” sag and ride feels much more stable. Not a bad solution for 200$
    Edit: read your post wrong. Thought you were pulling that weight, not carrying it.
  15. Aug 4, 2021 at 6:39 AM
    Timbren-Industries
    Timbren-Industries Well-Known Member
    Thank you for tagging us! Our Timbren SES kit will definitely get the job done and they're easy to install yourself!
