Do I need to buy UCA to go with this lift kit from Toytec?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wh013mi1k, Aug 22, 2015.
  1. Aug 22, 2015 at 7:44 AM
    wh013mi1k
    wh013mi1k [OP] Well-Known Member
    2012 DCLB TRD SPT V6
    I currently have a 2012 DCLB TRD Sport Upgrade and since I'm having to replace tires I'm putting in a lift kit while the wheels are off.
    I've ordered the 3" LIFT KIT WITH BILSTEIN 5100 FRONT COILOVERS from Toytec (seen here: http://toyteclifts.3dcartstores.com/3-lift-kit-with-Bilstein-5100-Front-Coilovers_p_364.html).
    I've been reading threads all morning and I'm finally just going to ask - do I need to buy new UCAs to go with this kit?
    I'm staying stock with the tire size (265/60-18) so this is just a lift for no other reason that to lift the truck up. I'm only stating the size because I'm not sure if it's relevant to the question.
    If I do end up needing new UCAs - does anyone have a recommendation?
  2. Aug 22, 2015 at 8:02 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Yes, you will. Some say that you may not and my guess is those who say that don't know what an actual alignment is other than the shop saying "it's within spec" which isn't acceptable to anyone who knows about alignments. I did something similar to what you have and 1deg position camber w/a shit castor setting was the best he could muster w/stock UCA's. I don't see how anyone would be satisfied with that. Unless you got money burning a hole in your pocket go with Light Racing UCA's because they'll give you plenty of adjustment for a 3" lift and use a similar-to-stock upper connection which means similar-to-stock maintenance which is nearly none. Other more expensive ones use a fancy ball that requires more frequent maintenance. Your call. Either way they're a pain in the ass to install but will get you a 0, 0, 2.5-2.8 alignment which is what you want for your rig. Do them all at the same time and save yourself some effort by not trying to do a 3" lift w/o them because you will end up doing the same work twice when you're unhappy with a negative castor & a nearly 1deg positive camber.
    Justinlhc likes this.
  3. Aug 22, 2015 at 8:06 AM
    wh013mi1k
    Thanks for the advice. Do you have a link to the right UCA I can buy? I've googled light racing UCA and it's taking me to a million places. Are you talking about the Toytec ones?
  4. Aug 22, 2015 at 8:39 AM
    Ostrichsak
    Jer
    I think many places carry them. I saw several being sold in the classifieds here for really good prices & brand new the last month or so. I was bummed because I had already bought mine and installed them. Might want to start your search there. If they're sold I'd just start with the popular vendors (Toytec for instance) and shop for the best price. I think I got mine from Headstrong Off-Road for like $375.99 shipped. The ones I saw for sale by members here were quite a bit cheaper than that and may or may not have sold already. I think Toytec's price was pretty close or slightly higher if you like to keep your business in one place.
  5. Aug 22, 2015 at 9:11 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    I could not agree more with that. :thumbsup:
  6. Aug 22, 2015 at 11:20 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OP dont even bother with that lift from toytec.
    You can piece together the same lift for just about half that price.
  7. Aug 22, 2015 at 11:31 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    You don't need UCA's. I have a Toytec Boss lift set at 2.5" and when I got my alignment the specs were identical to factory and when I looked underneath the eccentrics on lower control arms weren't maxed in either direction. I don't want to hear any "you don't know you're talking about in regards to alignment specifications" as I was a BMW technician and have plenty of experience with alignments.
  8. Aug 22, 2015 at 11:37 AM
    Justinlhc
    Please post your alignment sheet.
  9. Aug 22, 2015 at 11:44 AM
    YotaDriver631
    '18 Taco
    Not going to start an online war..
  10. Aug 22, 2015 at 11:54 AM
    Justinlhc
    I was simply asking for your alignment printout.
    If I told you I had X-ray vision you would want proof, right?
  11. Aug 22, 2015 at 3:02 PM
    nd4spdbh
    SoCal
    probably kept the back end stock or the truck has little to no rake forward... this helps with being able to run stock UCA's at lifts above 2inches.
    Now if your setup like mine and do 2 inches in all 4 corners to keep about 1.5in of rake its hard to get the desired caster numbers as the rake works against you in that sense.
    Also.... your stock UCA's probably hit coils at full droop.
    And lastly just because the adjustments are not maxed does not mean you are not maxed for caster. as changing those adjustments also change camber. so if you are aiming for 0 camber, you can only adjust the LCA so much forward or back while staying at 0 camber. any further then you start getting positive camber... which is bad.
  12. Aug 22, 2015 at 3:13 PM
    Mikehole
    Mikehole Well-Known Member
    SF Bay Area
    '12 4x4 Short Bed TRD Off Road
    TRD Supercharger, Toytec 3" Ultimate Lift w/ 285/75/16s and planning on OBA for sometime in the future. Also thinking about the HWMS and a Warn 8000 for it.
    I have the Toytec ULK and I didn't have the new UCAs for a year. It rode fine (I took it to Moab, and did some pretty hard off roading). I got the new LR UCAs and within a thousand miles the bushings in the UCAs started to squeak like hell (the UCAs were installed right before a second Moab trip). Whenever I go over a small swail it reminds me. The LR UCAs have no zerk fittings to help the squeak, so I might recommend something that does have them (I think the Total Chaos ones have them).
  13. Aug 22, 2015 at 3:18 PM
    Mikehole
    SF Bay Area
    Also, I added the supercharger, pelfreybilt front bumper and skids, and winch, and now the truck sits about even as it did with stock. I would like to change to some heavier springs, like you can with the OME lift. So there's that.
