Do i need to change anything ?
Discussion in 'Suspension' started by JOE619, May 21, 2013.
  1. May 21, 2013 at 1:57 PM
    JOE619
    JOE619 [OP] Well-Known Member
    broseph aka JOE
    San Diego !
    2006 TRD off road
    Bilstien 5100 front and rear, TRD intake, Yokohama A /T tires
    this is what i have currently for my suspension i have fox 2.5 coil over shock with a res and bilsitens 5100 in the rear. Im going to get all pro expedition leaf pack that adds 3' . Im also getting my down south UCA's.
    so Im just wondering if am i going to need to run anything els or will i be desert ready :D.
  2. May 21, 2013 at 2:01 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I hope you're replacing the rear shocks or have the extended version of the 5100s to pair with those Expos. Otherwise, you might end up needing extended brake likes for the rear and possibly extended bump stops. Also, you do realize that the Expedition springs are meant to provide that much lift when loaded, right? Unloaded, you'll likely be over 3" of lift.
  3. May 21, 2013 at 2:07 PM
    JOE619
    broseph aka JOE
    San Diego !
    2006 TRD off road
    so i would need extended brake likes shocks. are the bump stops need for this type of set up ? and i dident know that so my truck would be taller than the front if i dont add spindle right ?
  4. May 21, 2013 at 2:17 PM
    JOE619
    broseph aka JOE
    San Diego !
    2006 TRD off road
