Do I need to cut going to 285?
Discussion in 'Wheels & Tires' started by zakkblack, Jul 16, 2010.
  1. Jul 16, 2010 at 9:47 PM
    zakkblack
    zakkblack [OP] Member
    Zakk
    Ontario, Canada
    2010 TRD Sport
    Tri-fold cover, tint all around,
    hey guys, just have a question, running 265/70/17 Do I have to cut or trim anything if I go to 285/70/17 because I cannot for warranty purposes. I am looking at Mickey thompsons MTZs (I have an excellent deal) I know they are bigger...any suggestions to get a bigger tire without doing so?
  2. Jul 16, 2010 at 9:49 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    you gotta trim a little but not much well i didnt have to trim much at stock height with stock rims.i also add 1/4 inch spacer
  3. Jul 16, 2010 at 9:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  4. Jul 16, 2010 at 9:58 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    If the alignment is in spec and you have a 2.5" lift a little trimming is required and there may be some rubbing on the steel body mounts for the cab which is tolerable and only happens when the wheels is cranked over all the way. With only a leveling kit or less you may need to trim the steel back on the body mounts.
  5. Jul 16, 2010 at 10:04 PM
    zakkblack
    Zakk
    Ontario, Canada
    2010 TRD Sport
    I am getting a 3" lift next week but was only doing for the tires, but if i cant get them on without trimming i probably will stick with 265s
