Do I need to jack up truck to remove exhaust?
Discussion in 'Performance and Tuning' started by Submarinesailor, May 5, 2010.
  1. May 5, 2010 at 7:05 AM
    Submarinesailor
    Submarinesailor [OP] Member
    Connecticut
    2015 Limited (oooh shiny!)
    Hello! Getting ready to install a Flowmaster catback kit on my 2010 Access cab. Can the exhaust be removed without jacking/ramps?
    Thanks!
  2. May 5, 2010 at 7:11 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    You'll find it beneficial to put a jack under the passenger side frame to free up space between the rear axle and underside of the bed. Leave the tires on the ground.
    Your cat back system is probably in 3 sections, so install shouldn't be an issue either way.
  3. May 5, 2010 at 7:13 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    I backed up on some ramps, made it much much easier, especially if it's like the TRD and is one welded piece.
  4. May 5, 2010 at 7:19 AM
    Submarinesailor
    Connecticut
    Thank you! Awesome response
  5. May 5, 2010 at 8:36 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I did mine without jacking the truck up. Had plenty of room to work. Mine was a 3-piece magnaflow.
  6. May 5, 2010 at 8:43 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    did not jack up the truck
  7. May 5, 2010 at 8:51 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    didn't jack up the truck all it takes is a little maneuvering
  8. May 5, 2010 at 8:59 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I didn't jack mine up, but rolling it up on ramps like previously mentioned will help you out a lot...
  9. May 5, 2010 at 10:16 AM
    Submarinesailor
    Connecticut
    I've decided to spring for a powerbuilt jack/stand combo ($40) to make the job easier. I'm sure it'll come in handy later anyhow. Thanks all for your responses!
  10. May 5, 2010 at 10:19 AM
    Jigzor
    Pennsylvania
    Cool, good luck!
  11. May 5, 2010 at 11:49 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    My husband and I installed mine without jacking it up.
  12. May 5, 2010 at 12:33 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I took mine off and installed my catback dual exhaust without jacking the truck up.
  13. May 5, 2010 at 12:44 PM
    krytikel
    krytikel Well-Known Member
    California
    2017 Tacoma TRD Inferno sport 4X4
    OME lift
    Didn't have to jack up the truck for mine. Might want to drop the spare though to give you more clearance for that last rubber hanger near the tip of the exhaust ;).
