Do I need to re-tune or dyno tune my 3rd gen Tacoma if I have Magnuson supercharger and install gear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jon1993*, Dec 22, 2021.
  1. Dec 22, 2021 at 10:33 AM
    Jon1993*
    Jon1993* [OP] Member
    Do I need to re-tune or dyno tune my 3rd gen Tacoma if I have Magnuson supercharger and install nitro 4.88 gear?
    Grossomotto likes this.
  2. Dec 22, 2021 at 10:34 AM
    canaduh
    canaduh Well-Known Member
    2015 Trd sport 4x4
  3. Dec 22, 2021 at 10:35 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Need? No.
  4. Dec 22, 2021 at 12:33 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Presume you are AT and not MT ??? did you flash the Tune Magnuson sent you? If so what Version was it ? Seven? And if you added the gears after you completed the vehicle modification submittal (part of getting the Tune from them) then you should get with Ryan and get a modified tune for the added gears.
    With all that said - I have 4.88 and tune from Magnuson that came with the kit. Their (Magnuson) shifting logic is SHIT. I doubt their Tune will satisfy you when it comes to shifting. There will be an alternative to the Magnuson Tune for you that will meet your shifting expectations and performance. It is being developed by YotaWerx so watch their thread and stay in contact with @mZiggy .
    GL
  5. Dec 22, 2021 at 12:39 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Without a 4.88 tune, you can lose some speed off of the stock speed limiter. I believe it was about 108 on a stock truck and know that it goes down to about 83-ish with 5.29s.
    What @GoldenBrew said though.
    :cheers:
  6. Dec 22, 2021 at 12:56 PM
    Jon1993*
    @GoldenBrew It is an AT. I have not actually installed the Magnuson SC yet. It is still at the shop waiting to be installed, but it will be installed by the time I get the nitro gear. I'm not certain if it is version 7, but the Magnuson calibration would be used.
  7. Dec 22, 2021 at 12:59 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Dyno tune if they have the software and use street tires when dynoing for numbers.
  8. Dec 22, 2021 at 2:07 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    That depends. Are you doing both at the same time or did you already have the supercharger and are just putting gears?
  9. Dec 22, 2021 at 2:16 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The gear tune is only a change to the speed limiter. Setting the main speed limiter map to something unobtainable or flashing a 4.88 tune from Magnuson would have no other effect.
    Hell, I put a few miles on @mZiggy 's S/C tunes. They felt crazy good. LoL!
    sorevilo and Skydvrr like this.
  10. Dec 22, 2021 at 6:58 PM
    GoldenBrew
    Golden, Colorado
    I second this - I run / test @mZiggy SC tune and it is way better than the Magnuson Tune. Hands down better in another league than what Maggy is going to dump on you.
    sorevilo, mZiggy and tonered[QUOTED] like this.
