Do I need to remove the fogs to apply yellow laminex film ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wattapunk, Jun 9, 2010.
  1. Jun 9, 2010 at 3:54 AM
    Wattapunk
    Wattapunk [OP] Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Tried w/o success to remove the fogs. I tried with a screwdriver approach from the front of the fogs and was unable to undo both tabs. Am I suppose to approach it from behind the fogs? Will the info. I found below work for removal? (sorry, but the info was on another toyota forum,:anonymous:)
    To get it out, squeeze the plastic piece on the end of the adjustment screw, and then push in on the side pins, and then it will come out.
    [​IMG]This image has been resized. Click this bar to view the full image.[​IMG]
  2. Jun 9, 2010 at 4:53 AM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    The answer to your question is NO! Leave fogs in and apply the Lamin-x starting in the middle. Then with your thumb, press the film down in a circle motion from the middle to the outside edges. There is a short video on how to do it on their web site.
  3. Jun 9, 2010 at 5:44 AM
    jizzam93
    jizzam93 Well-Known Member
    Kris
    H-Town, TX
    08 DC PreRunner SR5
    YES!!
    x2... Also leave the foglight on to keep the lens warm. It's easier to work with.
  4. Jun 9, 2010 at 6:14 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    great! thanks..
  5. Jun 9, 2010 at 6:18 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Yes, leave them in.
    But if you feel you do want to remove them, I found that the tab that is toward the center of the truck could be removed fairly easily by pushing the fog casing tab toward the outside of the truck, from underneath the truck. So if you are removing the driver's side, push the inner tab toward the driver's side.
    Then to remove the other tab, I went to the front of the truck, and very carefully pried with a butter knife wrapped in a soft cloth, between the fog light casing and the plastic bumper fog light access hole, if that makes sense.
    The first one took me about 15 minutes to finaggle out, because I didn't want to break or scratch anything. But the second one took only about 2 minutes tops, once I got a good grasp on what was going on with it.
