Do I need to replace drive shaft too?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsnm23, Feb 20, 2016.
  1. Feb 20, 2016 at 7:25 PM
    jsnm23
    jsnm23 [OP] There are no solutions; only tradeoffs.
    2011 mgm TRD OR 4x4
    5100s @1.65 MB 352 wheels Debadged Cb radio Bhlm
    So I'm getting ready to replace my carrier bearing which is shot and u joints. I read somewhere that when you replace the carrier bearing its also recommended to replace drive shaft. Is this true? I hope not.
  2. Feb 20, 2016 at 7:32 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Definitely not without good reason. Unless a yoke or other part of the driveshaft is damaged, that would be like replacing your engine because you need an oil change and new spark plugs. Even then, individual yokes can be replaced, even the welded ones by any competent driveline shop.
    Match mark all pieces before disassembly and reassemble them exactly the same way to maintain your driveshaft's balance and phasing. In other words, be sure the only thing that's different is the new parts, everything else must be reassembled the same as it was in relation to each piece.
  3. Feb 20, 2016 at 9:13 PM
    jsnm23
    2011 mgm TRD OR 4x4
    That's what I thought. Wouldn't make sense to replace a perfectly good drive shaft.
    Thanks
