Do I need TPMS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pearing, Sep 25, 2020.
  1. Sep 25, 2020 at 1:16 PM
    #41
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I always, always jump on my son's shit about 'No.. NO! When you're backing up, you look over yer shoulder and actually LOOK BEHIND YOU!' He relies on his 'backup camera'.. (He hates driving with me ..)
  2. Sep 25, 2020 at 1:17 PM
    #42
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I think beside the FMVSS requirements, the TPMS came about from the Auto industry trying to meet CAFE regulations by eliminating the spare tire and the associated weight.
    IIFC, many models are sold without a spare tire.
    koditten likes this.
  3. Sep 25, 2020 at 1:20 PM
    #43
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    .I prefer to keep everything operational on my vehicle, I don’t need the tpms, but since I paid over 30k for the vehicle it’s a doable expense for me. I figure I will replace them once in 15 yrs of ownership and it will help me fetch a better price on a resale when the time comes if everything works.
    771Doug and NCAmother like this.
  4. Sep 25, 2020 at 1:59 PM
    #44
    Muddinfun
    Muddinfun Well-Known Member
    In the 50s, planes flew just fine with only a compass, altimeter, air speed meter and a radio. Based on the logic in this thread, there’s no need for all the nannies in modern aircraft. They probably even have a light on the dash that comes on if someone doesn’t flush. BTW, I wonder if airplanes have TPMS. I’ve never once seen a pilot check the tire pressure during his preflight inspection.
  5. Sep 25, 2020 at 2:38 PM
    #45
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    That is what I remember. Ford Explorer, Firestone tire issue, and drivers not monitoring their tire pressure. It started out as an Explorer issue, as it grew in size and weight, the tires were never upgraded to compensate. But, in reality, it affected any vehicle that carried a heavy load or towed. I still see plenty of vehicles with underinflated tires.
  6. Sep 25, 2020 at 2:44 PM
    #46
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    How do you manage that at 70 mph
    In 2011 I was driving 70-75 on an intestate highway when my warning light came on. I was able to get to the shoulder and stopped in under a minute. By the time I was stopped the right rear was completely flat from a 1/2" hole in the tread. With TPMS I had a few seconds warning to get stopped. Without TPMS I'd have had a tire come apart at 75 mph.[/QUOTE]
    The same way I've been dealing with tire inflation and flat tires since l started driving in 1979. I check my tires and go along my marry way. If a tire blows out, that doesn't mean that you are going to loose control and roll your vehicle. You put on your hazards, grab the wheel and only feather the brakes if you have too. Has always worked for me. People have survived without TPMS. Just like they survived without Lane departure warning, and side mirror sensors, and a host of other things. These things may be good. But you don't need them. Hence, people don't replace the TPMS sensors when the batteries die.
    A 1/2 inch hole in your tire, means that it deflated in a fraction of a second and you were then driving on the rim. A TPMS sensor wouldn't have made any difference in this situation. As the tire went flat extremely quickly. Prior to you getting over to the shoulder.
    I like the simple life and it has never failed me yet.
  7. Sep 25, 2020 at 3:06 PM
    #47
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I like the simple life and it has never failed me yet.[/QUOTE]
    I'm not sure common sense has a place in this thread...
  8. Sep 25, 2020 at 4:57 PM
    #48
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I remember That fiasco well.
    http://justacarguy.blogspot.com/2018/07/ever-hear-of-firestone-500-tire-recall.html
    https://www.washingtonpost.com/arch...etailed/0edea28f-877d-4af4-b2cb-91d45801fba4/
  9. Sep 25, 2020 at 5:12 PM
    #49
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Yes sir. I remember that too. The issue was related to the Explorer having a high center of gravity and when one of the rear tires would let go the truck would have a tendency to flip. Actually Ford ended a relationship they had with Firestone since the Henry Ford days.
    Jimmyh[QUOTED] likes this.
  10. Sep 25, 2020 at 5:26 PM
    #50
    spitdog
    They called them ford exploders back then
    Jimmyh likes this.
  11. Sep 26, 2020 at 5:02 AM
    #51
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Back then? Seems like it wasn't that long ago...
  12. Sep 26, 2020 at 5:47 AM
    #52
    spitdog
    I think it was in the 80’s wasn’t it.
  13. Sep 26, 2020 at 6:02 AM
    #53
    replica9000
    2019 T4R ORP
    BMH and spitdog[QUOTED] like this.
  14. Sep 26, 2020 at 6:20 AM
    #54
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Best I remember the Ford Explorer had no problems with any other tire except those Firestones. Those Firestone tires never had any problems on anything other than the Ford Explorer. I never knew if the Firestone tires were the problem or if there was a problem with how the Explorer was designed. Firestone having no problems with any other vehicles would indicate a problem with the vehicle. The Ford Explorer not having trouble with any other tire except the Firestone would indicate a problem with the tire. I never knew they figured it out.
  15. Jan 2, 2021 at 5:33 PM
    #55
    lickskillet
    lickskillet Well-Known Member
    Land Of Big Sticks
    2014 Tacoma
    Can anyone comment with a link to disable TPMS from coming on? I see lots of talk of it being possible but no links to the mod...
  16. Jan 2, 2021 at 5:42 PM
    #56
    koditten
    Kirk
    Central Michigan
    TPMS fix (tricking module not tape method)
    Tundratalk.net
    This where I found the how to get rid of TPMS for my Tundra. It should be the same for your Tacoma.
    lickskillet likes this.
  17. Jan 2, 2021 at 6:27 PM
    #57
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Just build a small sealed PVC pipe cylinder with a valve in an end cap. Put the idiot light triggers in the cylinder and pressurize it to 35. Keep somewhere in the truck.
  18. Jan 2, 2021 at 6:30 PM
    #58
    koditten
    Kirk
    Central Michigan
    Or just put them all in the spare tire. You will definitely know if you need to check spare tire air pressure.
    But I'm with the OP. Be done with the fuckers once and for all doing the bypass mod. I forget I even had them to begin with.
