Do I need transmission pan heater in fairbanks?
Discussion in 'Alaska' started by Jepoy_Cemento, Jul 29, 2019.
  1. Jul 29, 2019 at 5:26 AM
    Jepoy_Cemento
    Jepoy_Cemento [OP] Well-Known Member
    Alaska
    2019 Tacoma OR 6MT 4x4
    hello, ive been to fairbanks before. Stationed in eielson for 3 years and now im coming back but this time with my MT taco. Do i need more that the standard oil/engine block/battery heaters? Also, do i need to change the stock coolant in my vehicle? Bought the truck in vegas. I appreciate!
  2. Jul 29, 2019 at 11:02 AM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    I'd change the coolant to a 60/40 coolant/water mix, but the standard block, pan, and battery heaters are fine. It couldn't hurt to change your diff oils and MT oils to synthetic like Amsoil.
  3. Oct 8, 2019 at 7:45 AM
    AKyota77
    AKyota77 New Member
    Nick
    2009 black Tacoma. 5 speed 4X4
    3-2 level kit, LED dash, stereo system. front grill, lights, rear bumper.
    ditch the battery heater instead use a battery maintainer.. I've seen battery heaters burn down vehicles. if you have a 5 speed manual like I do, then a trans heater is a must.. @ -40 it will stay in gear with the clutch depressed. 60/40 coolant is good down to -40.. I run 70/30 that is good down to -50, although I run the Dalton all year and it gets dam cold on the north slope. but yes defiantly run synthetics like Amsoil... MT90 is what I found to work best for me.
    SnowroxKT and SR-71A like this.
  4. Oct 30, 2019 at 1:38 AM
    aktaco12
    aktaco12 Well-Known Member
    AK
    2012 4x4 DCLB TRD Sport
    Better to use a trickle charger for your battery. Plates & blankets can kill a battery over time.
    akgirlincali likes this.
  5. Nov 11, 2019 at 10:41 AM
    Ak-Alex
    Ak-Alex 2015 TRD PRO
    Alex Kiely
    Fairbanks, AK
    2015 tacoma Trd pro
    Trd pro package
    Trans heaters are not required on MT’s. Definitely change your coolant. I wouldn’t worry so much about the diffs or other fluids. I haven’t had any issue with my truck here in fairbanks.
    Add: I also recommend getting a slightly high CCA battery and a trickle charger. For those 40below starts. I upgraded to a optima yellow top
  6. Nov 11, 2019 at 10:45 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The heat from the block and oil pan heaters will radiate back and warm the transmission also.
  7. Nov 11, 2019 at 10:55 AM
    skierd
    David
    Fairbanks, AK
    I've had issues with slow-to-release clutches in other cars with manual transmissions, but my Tacoma is an AT so no idea if that applies or not to our trucks. I've always assumed it was due to the clutch fluid getting thicker in super cold weather as it only happened first thing in the morning when it was -30F or colder or after driving on the highway for a while at those temps. A fluid flush to a DOT3 or 4 fluid with lower viscosity at low temps should help.
