Do I need UCAs??
Discussion in 'Suspension' started by bowhuntingaddict, Aug 18, 2010.
  1. Aug 18, 2010 at 2:47 PM
    bowhuntingaddict
    bowhuntingaddict [OP] Well-Known Member
    I just got billy 5100s, and after I got the lift on the trcuk drove perfectly, no wandering or anything up to 80mph, but after I got new tires and got it aligned it started to shake, is this the tire fault or do I need new UCAs?
  2. Aug 18, 2010 at 2:50 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    tires may need to be rebalanced. what setting do you have the 5100's at. UCA's are recmmended for anything over 2".
  3. Aug 18, 2010 at 2:52 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Road force balanced
  4. Aug 18, 2010 at 2:56 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2
  5. Aug 18, 2010 at 3:04 PM
    bowhuntingaddict
    Its set at 2.5in, but i think I'll go get it road force balanced first
  6. Aug 18, 2010 at 3:22 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    definitly get a roadforce balance done, little pricey(25$/wheel) but well worth it.
  7. Aug 18, 2010 at 3:56 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    what is road force balanced? i've heard about it a few times on here. how is it different than normal balancing?
  8. Aug 18, 2010 at 3:59 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    its a different type of wheel balancing in which they find the heavy spots in the tire and wheel and sit the tire on the wheel in such a way that the heavy spots cancel eachother out and you get a better balanced tire/wheel.
  9. Aug 18, 2010 at 4:03 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Mucher cheaper to try and correct it via road force balance than to drop 400-600 on a set of UCAs.
  10. Aug 18, 2010 at 4:03 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    oh thanks. i recently had new tires installed, i wonder if they were "road balanced"? hmmmm....
  11. Aug 18, 2010 at 4:04 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    you may want to check firestone. if that doesnt work get uca's
  12. Aug 18, 2010 at 4:05 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Chicago
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    can you get away with road force balancing and not the regular balancing? or are they too different and still require regular balancing?
  13. Aug 18, 2010 at 4:05 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    x2. UCA's really have nothing to do with shaking/vibs anyway.
  14. Aug 18, 2010 at 4:27 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    i doubt it,a roadforce balance is usually something that you have to ask for since its more expensive
  15. Aug 18, 2010 at 5:10 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    you would think they would do it without asking because if its more expensive, then they'll make more money... either way, road balanced or not, my tires ride smooth so its all good!
  16. Aug 19, 2010 at 12:46 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    well I have 5100 set at 2.5" w/o vibration and pull L or R at all . Truck drive perfect No need UCA . Do you have aftermarket wheels or stockers ?
  17. Aug 20, 2010 at 9:44 PM
    bowhuntingaddict
    16in helos 4.5" backspace
  18. Aug 20, 2010 at 9:48 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    OP I believe I have the same wheels and they dont make hub centric models. We both have lugcentric, I havent had a problem but I think you might be having issues with that.
  19. Aug 21, 2010 at 12:41 AM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2018 WRX
    When are UCAs actually beneficial for a truck, i see above someone said 2" then it helps
    But when do you want to make the purchase of these?
    (I thought about making a thread but maybe this will work)
  20. Aug 21, 2010 at 12:59 AM
    sanga700
    San Diego, CA
    If sterling wheel shake You may need rebalance the tires or check lug nuts because lug nuts must go in all the way .
