do I need UCAs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1 loud trd, May 13, 2012.
  1. May 13, 2012 at 7:57 PM
    1 loud trd
    1 loud trd [OP] Member
    Rex
    Maine
    05 TRD Off Road
    Train Horn, Love Stains, Bent Tow Hitch.
    About to install 5100s @ .85 with eibach coils and 1/4" top plate spacers (passenger side & driver side to achieve full 3" lift) I'll also be installing front differential drop kit. I have 1.25" spidertrax and would like to run either 285/75R16's or if I go to a 17" wheel 285/70R17...will I absolutely need aftermarket UCA's or will I be able to get by with the stock UCAs??
    I don't know if this information is needed to answer my question but my rear lift is a 2" aal w/ axle shims and 5100s. Also, it's a 2005 double cable 4wd.
    Thanks for the help in advance!!
  2. May 13, 2012 at 8:07 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  3. May 13, 2012 at 8:21 PM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    X2
  4. May 13, 2012 at 8:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You dont know that. You SAY this.....but.....what would you say if he gets his lift on....goes driving around, big smile....Hand on your girls leg, then BOOM!......A fucking airplane hits him?? THEN WHAT!!!!! Perhaps had he simply installed the UCA's, the airplane would have hit the hippy in the scooby doo van!
  5. May 13, 2012 at 8:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:
  6. May 13, 2012 at 8:38 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How much height you get ?
  7. May 13, 2012 at 8:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Or....just dont drive under airplanes....
  8. May 13, 2012 at 8:43 PM
    OZ-T
    Peter North
    British Columbia
    Nice
    OME trim packer on driver's side too ?
  9. May 13, 2012 at 8:45 PM
    OZ-T
    Peter North
    British Columbia
    I'm adding 1/4" spacers to my set up too
  10. May 13, 2012 at 8:58 PM
    OZ-T
    Peter North
    British Columbia
    Yes , LR UCA's
  11. May 13, 2012 at 9:31 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I am currently running 5100's @ .85 with Eibachs and a 1/4" driver's side spacer for the infamous ' Taco Lean'. I have not replaced the stock UCA's.
    While my Camber is slightly higher than I would prefer, it is within spec. My Caster is lower than I would prefer, but is also within spec. I have noticed no problems with any road wander.
  12. May 14, 2012 at 7:55 PM
    1 loud trd
    Rex
    Maine
    05 TRD Off Road
    Sooo, kind of a mixed response here, but I think I'm going to have to make the stock UCAs work for a little while as I really need to buy tires as soon as I put my lift in. Will take before and after pics and post them to this thread...also, I'll let you know if I have to dodge any planes! ;)
  13. May 14, 2012 at 8:03 PM
    medic2230
    Murph
    Bama! Roll Tide
    bout time. Get that bumper on yet? :rolleyes:
  14. May 14, 2012 at 8:05 PM
    medic2230
    Murph
    Bama! Roll Tide
    Yes x whatever number we're up to now. :D Get the LR UCA's you won't be disappointed, my truck aligned perfect with them.
  15. May 14, 2012 at 9:38 PM
    Joshbomb354
    Joshbomb354 New Member
    Josh
    Edmonton, Alberta, Canada
    06 TRD Off-Road Tacoma
    Toytec 3" Lift Adjustable Coilovers SPC Upper Control Arms Satoshi Grill Double Din 7" JVC Head-unit JL Sound system 285/75r16 BFG All-terrain Ultra Motorsports Nomad 16" Wheels Custom Magnaflow Exhaust K&N Air Intake PIA Grill Foglights HID 6000k Headlights
    Get the UCA's. With alignment not at ideal setting excess wear can occur at joints, wheel bearings, and tire treads. But its up to you
  16. May 15, 2012 at 5:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm going to go with no... :cool:
  17. May 15, 2012 at 5:30 AM
    Pugga
    Massachusetts
    You can get the camber and toe within spec using stock UCA's. Caster being out of spec does not wear your tires unevenly, just causes a wandering feeling. The other option is to sacrifice some camber to gain some caster adjustment, in which case you'd wear the outter edge of the front tires.
  18. May 15, 2012 at 2:38 PM
    Hairy Taco
    North of Hell
    08 TRD
    this^^.
    My understanding is that the wear one needs to consider is at the cv joint. It is not a UCA issue. With a lifted front end the angles of the cv joint increase. This increased angle can sometimes stress the cv boot towards damage. If this happens this joint may lose its grease and fail. This is why some install a differential drop after a front lift. It is important to keep a close eye on this if you install a lift imo
  19. May 15, 2012 at 4:52 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    if you want your suspension to droop 1 inch and have your UCA hit your coilspring then you dont need them
  20. May 15, 2012 at 5:14 PM
    Hairy Taco
    North of Hell
    08 TRD
    this happened to you?
